Old 01-16-2020, 11:03 AM   #1
JDC
City & State: Wheeling, WV
I'm a: Hobbyist Tech
Default (SOLVED) 75UK6570PUB-BUSGLOR Lights up, no video
NOTE: TV WAS ORIGINALLY POSTED AS A D50U-D1. THIS HAS BEEN CORRECTED.
Issue: TV turns on, lights up, but displays no video.
Solution:
C106 surface mounted capacitor on the left panel board. Once this tiny capacitor is replaced, tv turns on without issue.
To find:
With TV turned off and panel boards (board connected directly to the panel) exposed, test for capacitor shorts. In this case, not only was C106 short, but it caused false shorts on other areas on the board. Replace, retest those that were short.
Capacitor was replaced with the same physical size capacitor. I do not know the exact rating.
Replacing the capacitor requires a microsoldering tip. You can get away with using hot air but I'd advise against that; the panel ribbons are too close the area that needs attention.
JDC is offline   Reply With Quote
Old 01-16-2020, 12:49 PM   #2
nomoresonys
City & State: midwest
My Country: U.S.
Default Re: (SOLVED) D50U-D1 Lights up, no video
Good to hear, thanks for sharing.
nomoresonys is online now   Reply With Quote
