List of pin compatible Laptop ICs
This is a sticky topic.
    Re: List of pin compatible Laptop ICs
    Hi, i need to replacea TPS51916...but can not find that specific IC. is there any compatible?
      Any compatible with jw5068c?, thanks
        up1565p =rt8207m J7=xx
        teasted on x455ld
          what do you think about using tps51211 instead of tps51218 ?
            Rt8207pgqw =up1565p
              what equivalent part of MX 25L 6473F m2 I 08g bios chip?
                what is the equivalent to BQ24715?
                  please HELP!!! battery driver BQ735/BQ24735 need compatible
                  i need a compatible battery IC driver for BQ735/BQ24735 for Asus
                  thanks in advance
                    Hi, I changed bq24738 instead of bq24726 on board RKY15HR-6050A2454801-MB-A01-20110317 and it worked ok, in this architecture pin 11 is not connected
                      Hi, looking for compatible ,found in THINKPAD T430
                      TPS74801DRCR
                      THANKS
                        Help Need Components,Mosfet Q2300,STMFS4854N,N-Channel,10 mOhm @3.2V,Macbook air,820-2838 A,I've been searching the net for a few days and I haven't found anything like it or equivalent, can you give me some advice, thank you very much
                          Re: IC Marking Codes and Datasheets
                          someone can help me please to find a replace ic for this please image attach below :
                          i know is a rt6256c but can't find a equivalent
                          thank you my friends
                            Can anyone help me find an equivalent
                            Motherboard 6050A2412801 MB -A02
                              Anybody know interchange for charger ic ISL 88738H
                                i have
                                51216
                                TI 83F
                                S13D IC
                                is there a substitute of this chip
                                  Pls help
                                  If u know rt3602ae equalavint ic.
                                    Hi If I'm going to get hold of a similar one as in the picture below MPKK 8690 3647 C, which numbers and letters are important
                                    Is it correct that something like this will work MP8690
                                    https://www.aliexpress.com/w/wholesa...55630&origin=y
                                    Why is there an underscore under 8 and what does the C in the lower right corner mean?
                                    I thinc this is the Electronic Components Datasheet
                                    https://www.monolithicpower.com/en/d...n/sku/MP86905/
                                      Hi, Looking for a replacement for intersil 95522H
                                      Can ISL95521HRZ be a good replacement ?
                                        ISL9538CHRTZ is faulty, can I replace it with ISL9538HRTZ?
                                          i replaced NCP81215DMNTXG with NCP81215MNTXG on ali Alienware m15 R2 Compal EDQ51 LA-H351P with success.
