HP EliteDesk 800 G2 SFF password BIOS dump
    please help me to unlock HP EliteDesk 800 G2 SFF BIOS password
    Re: HP EliteDesk 800 G2 SFF BIOS dump
    try..
      Originally posted by peste View Post
      try..
      thank you very very much its done
        Hi friends Need to see my 800g2 bios dump
        NO SCREEN only fan spining
          the posted bios is empty ... remove the bios chip from the motherboard before reading or writing ... if you use the clip, make sure it makes firm contact with the chip legs, otherwise it could give errors ... make more copies of the chip bios and comparisons with the HxD program, which are also posted ....
            Try this please ... also cant find here a dump file for 800g2 hp
              try..
                hi.
                Does anyone can tell me where to put this file? or how to use it? seems this is what i need...
                  This is goood dump
                  OKBALORD
                    Originally posted by okbalord View Post
                    This is goood dump
                    There is 2 files. Which one is which?
                      did you solve it ?
                      i have same problem
                        Re: HP EliteDesk 800 G2 SFF password BIOS dump
                        hi can i also get help unlocking this bios
                          hi..unlock it yourself..use RCUnlocker..you can find it here on the site..
                            Hi Friends I have this dump ..think its damaged cause 3 long beep and 4 short
                            please can anyone help
                              https://h30434.www3.hp.com/t5/Deskto...C/td-p/5609069
                              Become a Badcaps supporter
                              Thanks to all supporters.
                                I tryed new power supply... new ram...new cpu but still nothing it just get a full fan spin for 2 sekonds and then 3long and 4shirt beeps.. then i thought it might be a bios issue THANKS ANYWAY
                                  Ok. Try. HP EliteDesk 800 G2 Small Form Factor PC
                                    try..
                                    Thank you very much, it's done.
                                      pls guys remove password here.advance thanks
                                        try..
