Factory Resets Listing
This is a sticky topic.
    Re: Factory Resets Listing
    Originally posted by Drocker View Post
    Hi, read your introduction and I'm thinking maybe you could help me out with certain information!
    I have a plasma 42inches TC-p42gt25, I have had it for 3 years. The problem started last week.....the power will turn on but the picture and the sound refused to work. After 5 to 10 times of turning it on and off.....the picture and sound comes on. It's taking me almost 20 times now of on and off before I could watch TV. With little technical know-how that I possessed, I figured out that maybe it's the Main Board panel that needs to be fixed.
    I need your expertise as I'm thinking maybe you could tell me what actually might need to be changed!
    I live in Saskatoon, Canada.
    Please let me know what your suggestion is?
    Elias
    Drocker,
    To me sounds like a bad capacitor on the power supply board. Access the power supply board and check for bulge capacitors.
    Also, there is a thread for the specific TV you have, any other questions pertaining to that TV, please use that thread to ask questions.
      Factory Reset of Dynex DX-55L150A11 issues
      Thanks to this great forum and thread, I was able to access the service menu of a Dynex DX-55L150A11 and make the necessary changes. The issue I'm having now is that the set requests me to select language preference, picture mode and signal input every time the set is turned on. I'd appreciate any suggestions to alleviate this issue. Thanks
        Does anyone know the factory reset sequence for a LG 60PS80-UA plasma? I can get into service mode by pressing the menu button on the TV and the remote simultaneously for a few seconds and then entering 0000 as the PIN.
        Among the many options there, I can't find any that seem to be a factory reset.
        Thanks for any input!
        God bless you,
        D. R.
          Just stumbled across these - not read it all or used any - but may be useful
          JVC
          1.
          -Press the {MENU} button and go to the User Menu screen, make sure
          that the indicator (arrow) is pointed and highlights the "Picture Control".
          - The buttons on top of the remote are set to TV & VCR respectively.
          - Set sleep timer to "0" minutes and while it is displayed, simultaneously
          press the {VIDEO STATUS} & {DISPLAY} buttons.
          - The main service menu will be displayed with choices #1 through #9.
          - Press one of the corresponding number keys to enter that menu.
          - Use the {CH+} {CH-} buttons to navigate within a menu.
          - Use the {VOL+} {VOL-} buttons to change the values.
          - Use the {MUTING} button to memorize the changed value.
          - Use the {BACK} button to exit the service menu.
          2.
          Turn the TV on.
          Using the remote control:
          - Press the {INFO} & {MUTE} buttons at the same time.
          - The Service Menu will be displayed
          - Use the number keys to select the category.
          - Use the {VOL+} {VOL-} buttons to enter the category.
          NOTE: Some models don't have category selection.
          - Use the {CH+} {CH-) buttons to select item to be adjusted.
          - Use the {VOL+} {VOL-} buttons to change values.
          - Press the {INFORMATION} button to exit.
          3.
          Turn the TV on.
          # Press {DISPLAY} & {PIC MODE} buttons at the same time.
          # The Service Menu will be displayed
          # Use the number keys to select the category.
          # Use the {UP} {DOWN} buttons to enter a category.
          # Use the {LEFT} {RIGHT} buttons to select items.
          # Use the {UP} {DOWN} buttons to change values.
          # Press the {DISPLAY} button twice to exit.
          4.
          # Press the {MENU} button.
          # Select "Clock Set".
          # Set clock to 3:21 AM and press "Start Clock".
          # While a "Thank You" message is displayed on screen, press the {MUTE} and {MENU} buttons.
          # The Service Menu will come up.
          # Use {UP} {DOWN} to select items.
          # Use {LEFT} {RIGHT} to change values.
          # To exit, turn the TV Off.
          MITSUBISHI
          1.
          # Using the remote control press:
          {MENU} {0} {3} {5} {3} buttons.
          {MENU} {0} {3} {5} {7} buttons.
          # Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
          # {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
          # Press the {ENTER} button to save the change.
          # Press the {MENU} button twice to exit service menu.
          2.
          {MENU} {1} {2} {5} {7} buttons.
          {MENU} {1} {2} {5} {9} buttons.
          {MENU} {1} {3} {7} {0} buttons.
          3.
          {MENU} {2} {3} {5} {6} buttons.
          {MENU} {2} {3} {5} {7} buttons.
          {MENU} {2} {3} {5} {8} buttons.
          {MENU} {2} {3} {5} {9} buttons.
          * Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
          * {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
          * Press the {ENTER} button to save the change.
          * Press the {MENU} button twice to exit service menu.
          4.
          {MENU} {8} {2} {5} {7} buttons.
          Mits VZ8 chassis Menus
          Option menu, Menu 1270
          Service Menu, Menu 1257
          Convergence Menu, Menu 1259, 4 Fine,
          5 Coarse, 6 Misc.
          PANASONIC
          Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
          following remote control sequence:
          -select the SET-UP icon and select CABLE mode.
          -select the TIMER icon and set the SLEEP timer for 30 minutes.
          -press the ACTION button twice to get out of the menus.
          -change to channel 124.
          -adjust the volume to minimum (0).
          -Hit the VOL down button on the TV itself (not on
          the remote) and a red "CHK" should appear in the upper corner.
          -press the ACTION and VOLUME DOWN buttons (again, on the
          TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
          Select Serviceman mode. The POWER button on the remote control will
          select one of the five Serviceman Adjustment modes.
          The modes are:
          B - Serviceman VCJ SUB Adjustments. These include sub-tint,
          sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
          audio and video adjustment, and vertical size.
          C - Serviceman VCJ Cut-off adjustments. These include Red, Green
          and Blue cut-off, red and blue drive, automatic fine tuning
          (AFT), RF AGC (RF gain control), horizontal center, beam limit,
          etc.
          S - Serviceman Options Adjustments. These involce the PIP and
          clock.
          M - Serviceman MTS (Stereo/SAP) adjustments.
          CHK - the mode you first entered. Normal picture and sound, lets
          you check things over and still have a hotkey into the
          service menu.
          There is one more adjustment that isn't in the five modes, it's
          global. When in either the yellow or red CHK mode, you can press
          RECALL on the remote control to enter the purity field check mode.
          This lets you select a pure white, red, green, or blue screen. A
          good thing to walk away from if you just want to temporarily freak
          out the floor manager, but it will be fixed as soon as the TV is
          turned off. Oh well.
          To get out of Serviceman mode, press ACTION and POWER on the
          receiver simultaneously for at least 2 seconds. The TV will momentarily
          shut off and then comes back on.
          PE77U / PX75U / PX77U / PZ700U / PZ750U
          PD60U / PX6U / PX60U / PX600U
          PD50U / PX50U / PX500U :
          * Hold down the {VOL -} button ON THE PLASMA TV.
          * Press the {RECALL} button 3 times on the remote.
          * The Service Menu will be displayed.
          * Use {1} {2} on remote to navigate main menu items.
          * Use {3} {4} on remote to navigate sub-menu items.
          * Use {VOL+} {VOL -} on remote to change item value.
          * Write down all values before changing
          Once a value is changed, THE CHANGE IS MADE.
          * Power off to exit service mode and save.
          PA25UP / PD25UP / PX25UP :
          * Using the remote control:
          * Press the {MENU} button.
          * Set "Antenna A" to "Cable".
          * Select "Timer" menu and set sleep timer to 30 min.
          * Press {OK} twice to exit menus.
          * Tune to channel 124.
          * Press and hold {VOL -} button ON THE PLASMA TV.
          "CHK" appears in on top-left corner followed by 5 letter/numbers
          (which are the cumulative hours in hex numbers)
          * While the "CHK" is displayed, press the {OK} and {VOL+} buttons
          ON THE TV simultaneously to toggle between Modes:
          Red "CHK" for Serviceman- Yellow "CHK" for Aging
          * Press the {POWER} button on the remote to select one of the six
          Serviceman Adjustments Modes.
          A. MTS ADJUSTMENT
          B. CLOCK ADJUSTMENT
          C. VIDEO ADJUSTMENT
          D. HDEF ADJUSTMENT
          E. VDEF ADJUSTMENT
          F. DAF ADJUSTMENT
          G. OTHER ADJUSTMENT
          * Press {CH+} {CH -} on the remote to select the settings
          on each of Service Adjustment Modes.
          Write down the original values before modifying anything.
          It's easy to erroneously adjust the wrong item.
          * Press {VOL+} {VOL -} on the remote to change values.
          * Press the {POWER} button on the TV to exit the service menu.
          PA20UP / PX20UP :
          * Press "Setup" menu.
          * On "Mode" menu, select "Cable"
          * Press {ACTION} twice to exit menus.
          * While the "CHK" is displayed, press the {ACTION} and {VOL+} buttons
          Red "CHK" for Serviceman - Yellow "CHK" for Aging
          A. MTS ADJUSTMENT
          B. CLOCK ADJUSTMENT
          C. VIDEO ADJUSTMENT
          D. HDEF ADJUSTMENT
          E. VDEF ADJUSTMENT
          F. DAF ADJUSTMENT
          G. OTHER ADJUSTMENT
            More
            PANASONIC
            The modes are:
            etc.
            clock.
            service menu.
            A. MTS ADJUSTMENT
            B. CLOCK ADJUSTMENT
            C. VIDEO ADJUSTMENT
            D. HDEF ADJUSTMENT
            E. VDEF ADJUSTMENT
            F. DAF ADJUSTMENT
            G. OTHER ADJUSTMENT
            PA20UP / PX20UP :
            A. MTS ADJUSTMENT
            B. CLOCK ADJUSTMENT
            C. VIDEO ADJUSTMENT
            D. HDEF ADJUSTMENT
            E. VDEF ADJUSTMENT
            F. DAF ADJUSTMENT
            G. OTHER ADJUSTMENT
            PANASONIC LCDs / CRTs / RPTVs :
            * Hold down the {VOL -} button ON THE TV.
            Model PT45LC12:
            1. Press and hold Vol Dn on center panel and press recall button on remote until Work Mode is displayed on screen.
            2. Press and hold Vol Dn on TV and Swap button button on remote until Factory Adjust is displayed on the screen
            3. Use Channel Dn button to select Digital and press the Action button.
            PANASONIC PROJECTORS :
            1.
            * Go to "Options" menu.
            * Highlight "OSD".
            * Then press and hold the {ENTER} button,
            until the Service Menu is displayed.
            * Press the {MENU} button to exit.
            2.
            # Turn the Projector on.
            # Press the {POWER} button.
            # A "Power Off" confirmation will come up on screen.
            # Then press {LEFT} {UP} {DOWN} {UP} {DOWN}
            & {ENTER} buttons.
            # The Service Menu will be displayed.
            # To exit, turn the Projector Off.
            PLASMAS 8UK / 9UK:
            * Hold down the {VOL -} button ON THE PLASMA DISPLAY.
            * Press the {STATUS} button 3 times on the remote.
            (Status button is the one above Setup button)
            * The Service Menu (CAT) will be displayed.
            (CAT = Computer Aided Test Menu)
            * Use the cursors keys on the remote to select a mode.
            * And press the Action key {} to access the menu.
            * To exit each mode, press the {R} button.
            * To exit the CAT menu, press the {STATUS} button.
            * Press {POWER} button on the Plasma to exit the service mode.
            PLASMAS 3UY / 4UY / 5UY / 6UY / 7UY:
            (Status button is the one below Power button)
            Philips Magnavox
            # Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
            or
            # Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
            or
            # Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
            or
            * Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
            or
            * Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
            or
            * Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
            or
            * Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
            or
            * Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
            or
            * Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
            or
            * Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
            * Turn the TV off to exit the Service Menu.
            * With the TV off:
            Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
            To Factory Mode:
            Step 1 : Select the source "PC" and then turn off LCD-TV.
            Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
            Press "menu"button and bring up factory mode indication
              More
              PIONEER
              PDP-4214
              * Press the {INPUT} button on the remote.
              * The input list will come up.
              * Then press the {0} {9} {1} {7} buttons on the remote.
              * To exit, press the {EXIT} button on the remote.
              You can also press the back button when you are
              in each category to get back to the main menu.
              4th / 5th / 6th / 7th GENERATION MODELS
              * Make sure the Plasma and the Media Box are in standby.
              * Press {DISPLAY} button (just press, do not hold) and wait 3 seconds.
              * Press {LEFT} {UP} {LEFT} {RIGHT} {POWER} buttons.
              * The Plasma will turn on with the "Information" page displayed.
              * Press {MUTE} to move through the levels of menus:
              INFORMATION
              FUNCTION CHECK
              COMMON ADJ
              OPTION
              INITIALIZE
              * Press the {DOWN} button to move through individual menus.
              * To exit, power it down.
              3rd GENERATION MODELS
              * Power Down at the panel.
              * Hold down {INPUT} & {VOL+} buttons on the panel.
              * Turn on the Plasma at the panel.
              * The service menu will come up.
              * Scroll down using the arrow keys.
              RCA GE Proscan
              1.
              * Turn the TV off.
              * Press simultaneously the {MENU} {VOL -} {CH -} buttons for about 8-10 seconds.
              * The TV will turn on with the Service Menu displayed.
              * Press the {POWER} button to exit.
              2.
              * Turn the TV off.
              * Press and hold the {VOL -} & {CH -} buttons on the TV.
              * Release both buttons when the green power light comes on.
              3.
              To enter service mode, push and hold the {MENU} button on the set.
              While holding, press and release the {POWER} button,
              then press and release the {VOL +} button.
              You will now have some information on the screen: "P0 V0"
              To actually be able to change these values, you must push {VOL +} on the remote so the information reads V76. Then pushing on the Channel +/- will change the "P" value.
              P1 - 3 are error codes. If there is a problem with the set that can be self-diagnosed, the "V" will report the code. These codes are available in the RCA repair manual.
              P4 - 7 control the horizontal size, shift, vertical size and shift.
              4.
              On the front panel (FPA) of the F38310, simultaneously and quickly press the {CH -} & {DIRECTV} buttons. If successful, you should have displayed on the bottom of the screen:
              Version Number: XX.XX P:0 V:0
              (Note: Modifications to the parameters and values can be performed using the remote at this point. The remote must be in TV mode. To be sure, cover the IR bulb on the remote and depress the {TV} button, then you can use the remote for adjustments.)
              Before adjustments can be performed, you must enter the password code to enable the FPA (or remote) for access. Use the {VOL +) button to change V:0 to V:76. Once this is done, you can now change the parameter setting for the desired function.
              Be sure to write down the V: settings PRIOR to making changes in the event you need to revert.
              SAMSUNG
              1.
              # Turn on the TV on and select the input that you want to adjust.
              # Turn the display off.
              # In quick sequence on the remote press:
              {MUTE} {1} {8} {2} {POWER} buttons.
              # The TV will turn On with the Service Menu displayed.
              ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
              # Select the function and use the {VOL+} button to enter.
              # Save settings and exit by pushing {MUTE} twice then {POWER}.
              2.
              * With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
              * The TV will turn On with the Service Menu displayed.
              * Press the {POWER} button to exit the Service Menu.
              3.
              {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
              * Use the {CH+} {CH -} buttons to select items.
              * Use the {VOL+} {VOL -} buttons to adjust.
              4.
              {P.STD} {HELP} {SLEEP} {POWER} buttons on the remote.
              or
              {P.STD} {MENU} {SLEEP} {POWER} buttons on the remote.
              5.
              {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
              SANYO
              1.
              * Unplug the power cable.
              * Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
              * Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
              * Use the {CH+} {CH-} buttons to select menus.
              * Use the {VOL+} {VOL -} buttons to change settings.
              * Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
              * Press the {MENU} button or turn the TV off to exit.
              2.
              * Press and hold the {VOL -} button on the TV
              * Keep pressing the {VOL -} button until
              SANYO PROJECTORS
              1.
              * Press and hold the {MENU} and {INPUT} buttons on the projector simultaneously for 5 seconds.
              or
              Press and hold the {MENU} button for 20 seconds.
              * The "S" mark appears on the screen.
              * While the "S" is being displayed, press and hold the {UP} and {DOWN} buttons on the projector
              or
              {SCREEN} button on the remote for more than 3 seconds.
              * Adjust service data using the following control buttons:
              {OK} ................ A group number increases.
              {MENU} ............ A group number decreases.
              {UP} ................ An item number increases.
              {DOWN} .......... An item number decreases.
              {RIGHT} .......... An adjustment value increases.
              {LEFT} ............ An adjustment value decreases.
              * To quit the service mode, press the "POWER ON/OFF" button only once on the projector or the remote control.
              2.
              * Factory Menu Access:
              Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
              * The Factory Menu will be displayed.
              * Service Menu Access:
              Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
              * Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
              * To exit, turn the Projector Off.
              3.
              * Press & hold the {MENU} button on the Projector for about 10 seconds.
                More
                SANYO
                1.
                2.
                SANYO PROJECTORS
                1.
                or
                or
                2.
                3.
                SHARP
                1.
                * Unplug the TV
                * Press and hold the {VOL -} & {CH+} buttons.
                * While holding the above buttons, plug in the TV.
                * There are 5 category menus:
                Deflection - Signal - Feature - Fix Value - EEPROM
                * Use {CH+} {CH -} buttons to select a category.
                Note: Not all models will have 5 categories.
                Some will jump to 'Signal' category.
                * Use {VOL+} to enter the category.
                * Use {CH+} {CH -} buttons to select the item to be adjusted.
                * Use {VOL+} {VOL -} buttons to adjust the value.
                * Turn the set off to exit the Service Menu.
                SHARP LCD TVs :
                * While the LCD is on, unplug the power cable.
                * Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
                * When it powers up you will see a little "k" appear in brackets.
                * Then on the TV, press and hold {VOL -} & {CH -} down and release.
                * Use {CH+} {CH -} buttons to navigate
                SHARP PROJECTORS:
                1.
                * Press {INPUT} {UP} {DOWN} {ENTER} {ENTER} {MENU}
                buttons on the back of the Projector.
                * Now use the remote control to navigate through menus.
                * To exit the Service Menu:
                buttons again on the back of the Projector.
                2.
                * Press {UP} {UP} {DOWN} {DOWN} {RIGHT} {LEFT} {ENTER}
                buttons on the Projector (or remote ?).
                SONY
                # Using the remote control:
                # Turn the TV off.
                # Press {DISPLAY} {5} {VOL+} {POWER ON} buttons.
                or
                Press {DISPLAY} {5} {POWER ON} buttons.
                # Use numbers {1} and {4} to select the item to adjust.
                # Use numbers {3} and {6} to adjust the value of the data.
                # Press {MUTE} then {ENTER} to save new settings.
                # The words "WRITE" in red will show up in the upper right corner if saved.
                # Turn the TV off to exit the service menu.
                SONY PROJECTORS :
                * Service Menu :
                * Press {ENTER} {ENTER} {UP ARROW} {DOWN ARROW} {ENTER}.
                * Then {UP ARROW} when it asks: "Do you want to enter the Service Mode?".
                * Factory Mode :
                * Press {ENTER} {ENTER} {LEFT ARROW} {ENTER}.
                * Then {UP ARROW} when it asks: "Do you want to enter the Factory Mode?".
                * Any additional menus usually pop up under the main INFORMATION menu.
                * Access "Menu" and make sure "Status" is On.
                * Exit the "Menu".
                * Service Menu :
                * Select "Yes" when it asks: "Do you want to enter the Service Mode?".
                * Factory Mode :
                * Select "Yes" when it asks: "Do you want to enter the Factory Mode?".
                SYLVANIA
                * Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
                or
                * Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
                or
                * Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
                or
                or
                or
                or
                or
                or
                or
                * With the TV off:
                THOMSON
                1.
                * With the TV in standby:
                * Press and hold the {VOL -} & {PRG -} buttons on the TV.
                * Keep both buttons pressed until the TV turns On with the Service Menu displayed.
                * To exit, turn the TV Off.
                2.
                * While the TV is On, press the {POWER} button on the remote control to put TV in standby.
                * Turn the TV Off using the {POWER} button on the TV.
                * Using the buttons on the TV:
                * Turn the TV On while pressing the {PRG -} & {VOL -} buttons
                  more
                  TOSHIBA
                  1.
                  # Turn the TV on.
                  # Press the {MUTE} button three times on the remote.
                  # Press the {MUTE} button again on the remote and hold.
                  # Then press the {MENU} button on the TV's front panel.
                  # Release both buttons
                  # There should be a letter "S" on the upper right of the screen.
                  # Press the {MENU} button on the TV's front panel again.
                  # You are now in Service Menu.
                  # Use the {CH+} or {CH-} buttons to select the item.
                  # Use the {VOL+} and {VOL -} buttons to adjust the value.
                  # Turn the set off to exit the Service Menu.
                  2.
                  * Turn the TV on.
                  * Press and hold the {VOL-} button on the TV.
                  * Press and hold the {9} button on the remote.
                  * Use the {CH+} or {CH-} buttons to select the item.
                  * Use the {VOL+} and {VOL -} buttons to adjust the value.
                  TOSHIBA LCD's :
                  * Press the {MENU} button on the remote.
                  * Highlight the "Picture" icon.
                  * Press the {9} {3} {0} {1} buttons
                  on the remote control.
                  with the following Modes:
                  "Options" - "Adjustments" - "Selections"
                  * Use the {OK} button to access and
                  navigate through these Modes.
                  * To change values use {VOL +} {VOL-) {P+} {P-}
                  * To exit, press the {MENU} button.
                  ZENITH
                  1.
                  Service Menu #1
                  Press and hold the {MENU} button on the remote and
                  the {MENU} button on the TV at the same time,
                  until the first Service Menu is displayed.
                  * Service Menu #2
                  Repeat the above sequence:
                  until the second Service Menu is displayed.
                  2.
                  * Press and hold the {MENU} button on the remote
                  and the {MENU} button on the TV at the same time
                  * If a password screen comes up:
                  again, until the Service Menu is displayed.
                  3.
                  * Press and hold the {MENU} button ON THE REMOTE
                  until a 4-digit password screen is displayed.
                  * Then try any of the following codes to
                  access the Service Menu:
                  {0} {0} {0} {0}
                  {7} {7} {7} {7}
                  {8} {7} {4} {1}
                  4.
                  * Press and hold the {MENU} button ON THE REMOTE.
                  (The menu on the screen will disappear)
                  * Now Press and hold the {MENU} button ON THE PANEL.
                  * Keep both buttons pressed until the Service Menu is displayed, then release the 2 buttons.
                  * Using the remote control buttons:
                  {MENU} = Toggles between two menu pages.
                  {UP} {DOWN} = Selects the item for adjustment.
                  {LEFT} {RIGHT} = Varies the value
                  {POWER} = Exit service mode and saves adjustments made.
                  5.
                  * Turn the TV on.
                  * Hold down the {MENU} button on remote until the on-screen menu
                  disappears or "Welcome Message" appears then release the {MENU}
                  button and within two (2) seconds press the following five buttons:
                  {9} {8} {7} {6} {ENTER}
                  or
                  {9} {8} {7} {6} {DISPLAY}
                  Vizio
                  With power off, hold Ch UP and Ch Down together for 10 seconds.
                  While still holding Ch up and down together, push power, then let go.
                  Select OSD button, there should be a letter in the lower right hand corner of the menu.
                  Then hold OSD and Mute/Exit buttons together until factory menu comes up. Make adjustments with remote, select exit, then turn off power to save the adjustments.
                  Hitachi
                  RPTVs :
                  F59 SERIES
                  * Press and hold the {MENU} button on the TV.
                  * Then press the {MENU} {8} {SELECT} buttons on the remote.
                  * To exit, press the {MENU} button on the TV or
                  the {EXIT} button on the remote control.
                  DCAM Mode:
                  * Hold down the {TV} button.
                  * Press the {INFO} button.
                  * Release the {TV} button.
                  * Remote Control Key Functions When In DCAM Mode:
                  {INPUT} ............. Blue (13x9 adjust)
                  {ASPECT} ............ ROM Write
                  {DAY/NIGHT} ......... ROM Read
                  {MENU} .............. Remove Color
                  {EXIT} .............. Cross Hatch/Video Mode
                  {INFO} .............. Green
                  {GUIDE} ............. Calculation
                  {2} ................. Cursor UP
                  {5} ................. Cursor DOWN
                  {6} ................. Cursor RIGHT
                  {4} ................. Cursor LEFT
                  {0} ................. RED (7x5 Adjust)
                  {STOP} .............. Initialize
                  {PLAY} .............. Raster Position
                  {FAST FORWARD} ...... Phase
                  To Exit The DCAM Mode:
                  * Press and hold the {TV} button.
                  * Press the {0} button.
                  * Press the {1} button.
                  HITACHI PROJECTORS :
                  * Press the {MENU} & {RESET} buttons and then press
                  the {RESET} button again and hold it for at least 5 seconds.
                  HITACHI MISC :
                  1.
                  * Turn the TV on.
                  * Press the {MENU} {MENU} {8} {SELECT} buttons on the remote.
                  * Use the {UP} {DOWN} buttons to select items.
                  * Use the {LEFT} {RIGHT} to change the data.
                  * Press the {EXIT} button to exit the Service Menu.
                  2.
                  * Turn the TV off.
                  * Press and hold the {INPUT} button on the TV then press {POWER}.
                  * Hold both buttons until the TV powers on
                  3.
                  * Turn the TV off.
                  * Press {POWER} & {INPUT} buttons on the TV for more than 3 sec.
                  * The letter "P" indicates picture and "A" indicates audio.
                  * Press the {EXIT} key to exit the Service Menu.
                    [snip]
                    Thanks for the Hitachi codes.
                    Last edited by tom66; 02-23-2015, 04:56 PM. Reason: snipped long quote, post above is what it's referencing
                      THANKS SIR MY LCD TV SAMSUNG NOT SOUND
                      I TRY WITH
                      Vizio Service Menu Method 2
                      1. Turn The TV off.
                      2. Press and hold the {CH +} & {CH -} buttons on the TV.
                      3. Then press and hold the {POWER} button on the TV.
                      4. Keep all three buttons pressed for few seconds.
                      5. Now press the {MENU} button on the remote.
                      AND SOUND IS BACK
                      MY PROBLEM IS SOLVED THANK YOU FOR YOUR SHARING
                        This is great info, but would you know what to do if the remote control is not functioning? I was told to reset to factory defaults using this method to get my IR receiver to see my remote again. Without a remote I cannot currently enter any numbers thus I am stuck. Thoughts? Thanks much for all the help.
                        Originally posted by randtek View Post
                        Over time, I have created a listing of manufacturers and their factory reset/factory mode procedures that may help others. This list is from my own experience, and is by no means complete for any given manufacturer. Some have been found by searching the internet, some by trial and error. I hope some may find this information useful
                        **** WARNING!!!! ******
                        Some of these procedures may allow you to enter factory service modes. IF YOU DO NOT KNOW WHAT YOU ARE DOING, DO NOT MAKE CHANGES TO SETTINGS IN FACTORY MODES!! Improper settings may cause undesired operation, and could result in a situation where your TV cannot boot/turn on.
                        YOU ARE USING THESE PROCEDURES AT YOUR OWN RISK!!
                        Factory Resets / modes
                        For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
                        If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
                        Coby:****************************************-
                        Enter menu, hi-lite “audio” then enter 8893
                        mode/source 2580 select “other setting”,select “shipment” then yes, after it exits service menu you need to power set off.
                        Dynex ****************************************-
                        source/input 2580
                        hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
                        source/input 2580
                        menu 1999 (tv is on)
                        Element ****************************************
                        menu 0000
                        menu 1147
                        Haier ******************************************
                        pull up menu, hi-lite “audio” then enter 8893
                        Hisense *****************************************
                        In customer menu go to”Parental” enter 0000 then select”Clean All” then power the set off and back on and first time setup menu will be there.
                        For some models, same as above model except in menu it is labeled “Lock”
                        Insignia *****************************************-
                        input 2580 (tv is on)
                        Mitsubishi ****************************************
                        Menu 123 or menu 2470 (tv is on)
                        Panasonic
                        Hold vol- on TV, press and hold menu button on remote
                        Philips ******************************************
                        Push menu, select”Features”then select”current software info” push 062596-info on remote then push info again then red”initialize appears and changes color then complete. Push power button to exit
                        TV is on,push 062596-info on remote,then push info again, red”initialized”appears it turns green when completed, then push power button to exit
                        Polariod *****************************************-
                        Hold vol- and chan- or hold vol+ and chan+ (tv is on)
                        Proscan ******************************************
                        In customer menu go to setup,select parental control menu, enter 0000 then select “clear channel list”.
                        RCA *******************************************-
                        Menu 1147
                        Sanyo *******************************************
                        hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
                        Samsung *****************************************-
                        Mute 182 power (tv is off)
                        (On some models, Factory Reset is on this menu, on some, you must go into the “Options” submenu
                        Seiki ********************************************-
                        Menu 0000
                        Sharp ********************************************
                        (Note – On Sharp models, you will need to look through the menus to find the reset option)
                        menu 1999
                        menu, 3481
                        menu 1147
                        while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan-
                        Sony *********************************************
                        Hold “arrow up” on remote and push power button on tv (tv is on)
                        Symphony *****************************************-
                        Source/input 2580
                        Toshiba ******************************************-
                        on Menu, select “Installation”, then “System Information” press the right arrow button, (“System Information” will change to “Factory Reset” or something similar) follow on-screen instructions
                        Vision Quest ***************************************-
                        Source/input 2580
                        Vizio ********************************************
                        In customer menu under “Help” tab is Factory Default enter 0000
                          good day, i have a 42" tv with one of those generic chineese boards, tp.ms608.p83 to be exact. it is stuck at the android boot logo. id like to know how do i go about fixing this.
                            JVC reset provided by CraigR:
                            https://www.badcaps.net/forum/showth...934#post547934
                            https://www.badcaps.net/forum/showpo...18&postcount=8
                            Tv jvc lcd hd don't turn on blue liht blinking
                            For Models: LT-32E479, LT-32EM49, LT-32P679, LT-42X579, LT-42SL89, LT-42EM59, LT-42P789, LT-46SL89, LT-47X579, LT-47EM59, LT-47P789, LT-52X579, LT-52P789 After the TV is powered ON, no video appears and the power LED at the lower left of the TV begins flashing:
                            Restore the TV's normal function by changing the operating mode. Please follow the procedure below.
                            PROCEDURE
                            • 1. Unplug the TV or remove AC power from the TV
                            • 2. Count to ten, then plug in the TV
                            • 3. Locate the [Menu], [Vol-] and [Power] button on the TV's side panel
                            • 4. Using the buttons on the TV's Side Panel, press and hold both the [Menu] and [Vol-] buttons.
                            • 5. While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [Vol-] buttons.
                            • 6. The TV's lower left Blue Power LED will come ON.
                            • 7. Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
                            a. The TV may have turned ON. If so,continue at step 12 b. If the Blue LED on the TV's Lower Left corner remained ON, continue to step 8.
                            • 8. After confirming that the Blue LED is ON, unplug the TV or remove the AC power from the TV.
                            a. If the Blue LED on the TV's Lower Left corner is flashing, restart the procedure from step 3
                            • 9. Count to 10, then plug in the TV
                            • 10. The TV power should automatically come ON but no picture will appear. Only the blue power LED will be ON
                            • 11. Wait 40 seconds and the TV picture should appear
                            • 12. When the TV picture appears, you may begin normal use of the TV. (procedure is complete)
                              Does anyone know factory reset for toshiba 50l4300u, I mean factory reset that will erase current firmware? Or are there any other way to restore firmware to a previous one. Thanks
                                BEFORE YOU buy a new main board board for any Vizio TV that is stuck on the Vizio logo try to reset the tv by doing these steps. I had to turn tv on then hold down on menu on keypad and press menu on the remote then release menu button on remote and press 1991 on remote then let go of menu on tv. Once your there go down to reset tv and it should re flash eeprom chip and that's it. It worked for me.
                                  More info:
                                  http://www.askvg.com/secret-service-...ony-and-lg-tv/
                                    "OKI" tv brand (also "Precision" brand) SERVICE MENU
                                    1 "MENU" in r/c
                                    2 press 4725 4725 (twice)
                                    3 In Service menu go to "DIAGNOSTIC"
                                    4 Then "FACTORY RESET" and press "OK" in r/c
                                    Tested in OKI L22VB-FHTUV
                                      i have tv samsung model ln46a500t1f probleme picture distortion no good picture bad
                                        Dear all Friends,
                                        i replaced tv logo from HISENSE to WELCOME. But i want to replace it with my own logo like my name DEEPANSHU. So how can i do it?
                                        Kindly help i need it.
                                          Hello, I'm new to the forum and new to forums in general. My name is Jon, nice to meet you all.
                                          Does anyone know how to a factory reset or access the service settings on a Logik L24DVDB19 Television? I have searched for so long for an answer, to no avail. I'm beyond frustrated.
                                          All the best
                                          Jon
