My folks' TV quit working so they asked me to take a look at it. It's a TH-42PX80U. It'll power on with no blinks. The panel primes but that's it. No response to the remote, no picture or sound. From what I read, the A board, TNPH0716 has failed. It looks like there are multiple repair services available on the net for anywhere from $110 to $160. Usually, when I see repair services, it doesn't take a lot of digging to find a detailed description of the service being done. That isn't the case with this board. I can't find any info. Any of you have any idea where to start checking for failed components? Thanks.
Panasonic TNPH0716 repair, anyone know what's wrong?
Re: Panasonic TNPH0716 repair, anyone know what's wrong?
Pull off L4513 too.
Could be bad IC4511, or shorted MLCC C4603.
Does IC4511 get warm/hot?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by johnboy1313 View PostI reseated the ribbon cables and it's working. I've ordered some ChipQuik and the IC. We'll see how it goes. Locutor13, thanks for pointing me in that direction.
No polarity for normal inductors. If it is a coupled type (more than two pins) then it might matter.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The chip arrived this morning and I quickly went to work replacing it. The old chip came off with no fight whatsoever. The ChipQuik is amazing. I couldn't be happier with it. I wicked all of the pads and the new chip went on without a hitch. I put the board back in and fired it up. HDMIs 2 and 3 both work fine. HDMI 1 doesn't work. I went back and looked at the chip. None of the pins are bridged and all pins are soldered to their appropriate pads. The two caps, C4599 and C4601 are no longer shorted. At this point, I don't know if it's something I did or if HDMI 1 has a separate issue. I wonder if I didn't get that little inductor soldered on correctly, though it appears to be.
Here are the pics from the IC replacement.
https://www.badcaps.net/forum/showthread.php?t=42837
From memory, front HDMI has a separate buffer chip which could have also failed...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
