Panasonic 48" LED TV, backlight on but no picture
  • safesurfer65
    • Feb 2014
    • 112
    • Scotland
    Hello all
    Have a Panasonic 48" LED TV model no. TX-48AS640B. Just over 1 year old. When switched on the backlight comes on but no picture is displayed. Can hear the menu being navigated. Suspecting main board, any ideas ? Hope someone can help.
    thanks
    Mal
  • truep
    • Aug 2010
    • 373
    Re: Panasonic 48" LED TV, backlight on but no picture
    Check for voltage on both sides of the TCON fuse. It should be near one of the connectors
    going to the main board. If you send a clear picture of the TCON board we should be able to point it out. (it's the one at the bottom of your picture) There should be 12V or 5V on both sides of the fuse. Some nay not have a fuse though.
    • safesurfer65
      • Feb 2014
      • 112
      • Scotland
      Hi
      Thanks for that. Think I identified the fuse (circled). 12v both sides !
        Try having one ribbon cable between the T-CON and the LCD panel connected one at a time to see what you get on the screen.
        • safesurfer65
          • Feb 2014
          • 112
          • Scotland
          Hi
          Tried disconnecting individual and both cables from the T-con to the screen. Made no difference.
          thx
          • wreksta
            • Aug 2013
            • 508
            • england
            Hi all been a while I too am facing this blank screen issue on same tv any info and tcon fuse tests fine
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4278
              • Italy - Milan
              You have lost too the warranty proof?? :-)
              The defect seem sto stay on tcon, can someone pubblish a shopjimmy picture of that board? i can't connect to it.
              • sordids999
                • May 2013
                • 2149
                • uk
                recently done a 40 inch panasonic with bad LEDS just a thought though
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Backlight on no picture......
                  • sordids999
                    • May 2013
                    • 2149
                    • uk
                    opps i must read more before posting
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Lolol
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4278
                        • Italy - Milan
                        Jesus Christ that smokes? That changes capacitors?
                        Also Jesus Christ chooses... PANASONIC...
                        • wreksta
                          • Aug 2013
                          • 508
                          • england
                          Hi has anyone resolved this issue I've tried tcon and to no Avail have the new main board so will post back when fitted
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Keep us updated
                            • wreksta
                              • Aug 2013
                              • 508
                              • england
                              well thats the main board and tcon replaced for good working ones and still nothing but a blank screen
                              also checked out all screen tabs etc no damage faults etc
                              im starting to think its the psu but nothing visual or blown
                              does any have a service manual or know the voltage the power board gives to main
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Fuse on panel FRP boards?
                                • wreksta
                                  • Aug 2013
                                  • 508
                                  • england
                                  fuse on frp where is this fuse like mate
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Located in the long boards that are attached to the panel itself. They are concealed within the frame.
                                    Of course this is just a hunch. I have seen panels that have fuses built on to these boards as a precautionary secondary step incase t-con fails
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4278
                                      • Italy - Milan
                                      Are you sure the backlight is present like OP?
                                      • sintv
                                        • Feb 2015
                                        • 37
                                        • scotland
                                        I recently had Vestel type 48" Toshiba with backlights ok but no video. Turned out to be the PSU though I didnt get to component level
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Bazfletch3
                                          Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                          by Bazfletch3
                                          Hi all
                                          While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                          I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                          From there I envisaged that the backlighting wasn't working, however...
                                          01-08-2024, 10:18 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Attila Jamilov
                                          Which fuse is responsible for backlight on Lenovo Thinkpad T14 Gen 3
                                          by Attila Jamilov
                                          I upgraded display from HD to UHD recently, and I think I did everything right, battery was disabled in BIOS, and removed, yet the screen has no backlight. Both the old and new display behave the same way. I checked the motherboard and I see the fv1 fuse, and a fv2 spot for a fuse, but it's missing. Does anyone have any information on whether fv2 is responsible for backlight, or why it's missing? There's a schematic posted somewhere on this forum, but I can't view it as I don't have the hardware right now, since the laptop screen is broken and I run Linux.
                                          Also from further search...
                                          04-20-2025, 10:02 PM
