Re: LG 42ld750 TV not turning on (3.4v on ERROR pin of power supply)
The chip is most definitely BGA (ball grid array), not socketed, so do not attempt to remove it off the board entirely ! You will not be able to put it back in place on the balls ! Heat it enough so the solder balls melt and that's it - that's the most you can do without a BGA machine. You have to hit it pretty hard so the balls start melting. You want the air to be hot enough to make the balls liquid, but not hot enough so they combine and form a big blob underneath (game over in that case). The chip itself is probably failed in some way, so I doubt even a proper reball would get it going....unless someone else confirms otherwise...
