Old 10-21-2018, 07:48 PM   #1
sputnikoff
City & State: happy valley newfoundland
My Country: canada
Default LG 55LB6000 flickering screen
Got a Lg 55LB6000 in today.Screen was flickering and when removed back could see lamps were issue.Did a tear down and found the top two rows were not illuminating.Apparently they are 6 volt leds cool white.Got 1 shorted and 2 burnt out.Where is good source for these leds?Any one know specs on these leds?
sputnikoff is offline   Reply With Quote
Old 10-22-2018, 07:36 AM   #2
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
Default Re: LG 55LB6000 flickering screen
There would be ID Nos. on the LED strips when you tear down the Panel.
Andrew F. Ali is offline   Reply With Quote
Old 10-23-2018, 12:52 PM   #3
sintv
City & State: cowdenbeath
My Country: scotland
I get my leds from Ebay chinese sellers. Good prices and havent had any issues. Search for LG smd led
sintv is offline   Reply With Quote
Old 10-23-2018, 02:57 PM   #4
Andrew F. Ali
There are 3V and 6V LEDs. I think the LGs use the 6V SMD LEDs. I prefer however to replace all the strips with new ones as I don't like to goin a Panel more than once, especially those 55inchers
Old 10-23-2018, 08:04 PM   #5
sputnikoff
My Country: canada
yes ordered 50 6 vdc lg leds.gonna order strips from shop jimmy just in case.
Old 10-23-2018, 11:49 PM   #6
neilc6
City & State: BC
My Country: Canada
The thick lenses appear to use the 6V LEDs and the thinner lenses with 3 black dots use 3V LEDs. I did a full strip replacement on a 32" LG with the thicker lenses and popped off almost every lens since they were difficult to remove with the double sided tape.
neilc6 is offline   Reply With Quote
Old 10-24-2018, 05:53 AM   #7
Andrew F. Ali
That's right the thicker lens are the 6V and the thinner lens with the 3 dots are the 3V LEDs.
Old 10-24-2018, 07:08 AM   #8
sordids999
sordids999's Avatar
City & State: United Kingdom
My Country: uk
Line Voltage: 240v
I'm a: Hobbyist Tech
Off topic here I'm reluctant to do these led repairs due to even heating up the led strip which is stuck down they nearly all fall of so my question is which way do they go back on because many times I have put these back on and ended up with a halo effect on the screen
sordids999 is offline   Reply With Quote
Old 10-24-2018, 09:31 AM   #9
neilc6
City & State: BC
My Country: Canada
You may get halos if the lens isnt perfectly centered, or not level or sitting too high. Can also be caused by the strip not sitting flat against the chassis. I scrape down the black nubs on the 3V lenses with an exacto knife before gluing down. Also better to swap repaired strips to the edges instead of middle of the screen if you can.
