Bad TV tuner. Repair or replace ?
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. It's been a while since I've actually had to do any TVs over at this new shop and I must admit I'm a bit rusty and need some help. Here goes:
    Someone brought in a little piece of junk Sony knock-off portable TV saying it no longer tunes any channels. Fair enough, I warned the chap it's not going to be worth repairing it, but he insisted I have a look at it, so here's what I found:
    Initially, a 5v buck regulator IC was blown (an LM2596), causing it to output 10v instead of 5v. That's been taken care of, but I believe it killed the tuner IC, since its maximum VCC is 5v and it took 10v like a trooper
    I then popped the metal lid off the tuner and was greeted with the green sh!t you see in the first picture. I thought it's corrosion, but it's actually that green UV gel stuff they use to seal components on boards (Louis Rossmann actually calls it something but I forgot what it is) and due to the high heat generated by the chip, this thing turned solid and crumbly. I removed the green stuff and cleaned the area as best as I could with some q-tips and alcohol. I also noticed the metal can of the tuner got rather hot when the TV is on and it's apparently coming from this chip (the TDA6500TT). Spritzed some alcohol on it and sure enough, the puddle evaporates in the middle, leaving a round "hole" in the very middle of the liquid, which I believe is not OK and it's overheating. There's another chip there, a TDA 9886 which could've suffered the same fate, since they're in parallel.
    It's also here that I realized that I don't know sh!t about TV tuners, the components inside of them and how they work and it would be an opportunity to learn...the datasheets for these ICs went a bit over my head, as beyond checking their VCC input, I'm not familiar with any of that stuff...frequencies and graphs and stuff.....:|
    I also lack a scope, so the world of tuners is a pretty cruel one to be in at this point There's so much stuff to go over and I'd need a lecture on TV tuner basics and what to look out for when troubleshooting. Do you usually replace the whole can or do you dig inside and do component-level repairs ? What are the most common faults...stuff like that. It's probably trash anyway, but still....cheers and thanks.
    Wattevah...
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Bad TV tuner. Repair or replace ?
    Repairing TV Tuners are a real pain, even for the experienced Tech. I would recommend setting up a TV Tuner separately. Once you can determine the AGC, VCC and IF OUT points. BTW you do have voltage at these points from the Mobo?
    • R_J
      • Jun 2012
      • 9535
      One thing I will say right off the top is, do not atempt to straighten or move any of those wire coils, That is how the tuner is fine tuned, they look like a mess but thats how it works at those high frequencies
      Check if you have VT on pin 15 of the tda6500, it should change between 1-33 volts depending on the channel, as you change channels the voltage should change, if it does, the ic might still be ok.
      The tda6500 does the channel selection and outouts an I.F. signal, The TDA9885 takes the I.F. signal and demodulates it give you the audio and video signals. Can you recieve anything at all ? even noise (snow)?
      Post the numbers from the tuner, it may be available as a complete module.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Correct.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Reminds me of toothpaste, LOL
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Yes, that is one thing I was familiar with, so I didn't do that. I knew they were like that for a reason.
            The part number is on the lid here, but couldn't find anything on it.
            No signal whatsoever - blank screen all throughout the search process, even with the antenna cable from the wall so to say (it's got its own aerial but I don't expect that to tune anything). And yes, my co-worker was able to tune an analog TV on that cable, so there still is ATV on it and should work...I though that was the reason all along, but no.
            Wattevah...
            • R_J
              • Jun 2012
              • 9535
              I looked up the board number and found pictures with the tuner Pt# JS-6B2/121
              https://www.aliexpress.com/item/NEW-...585127520.html
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                Interesting. Must've missed that one.
                Wattevah...
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  Ja, see that's what I was talking about: learning about how these things work and their internal organs
                  Wattevah...
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Also, when I measure that VT pin while changing channels, should this be with the antenna lead plugged in, or it doesn't matter ?
                    Another question: do these TV tuner cans share the same pinout generally ? What makes them different to one another ? I was thinking about all those leads coming out of the can...I can speculate what a few of them are like VCC, SCA, SDL, video, audio, clock (?) but that's as far as my knowledge gets me.
                    EDIT: let me answer my own question. I was able to find THIS. If you look to the right, it brings up a datasheet which is mostly in chinese but includes a pinout of the damn thing nonetheless. Turns out I was right about some of those pins.
                    Wattevah...
                    • R_J
                      • Jun 2012
                      • 9535
                      The TV voltage (tuning voltage) will change depending on the channel and no input is necessary. The voltage will change from 0-32 v as it goes through the channels of the band that is selected . This is only a monitoring point for the ic and may or may not go to a module pin.
                      I found this site http://www.radioscanner.ru/forum/topic23937-19.html
                      They seem to have the pinouts
                      The ic has an internal charge pump to develope the 32v VT
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        32 v...must be a boost converter in the there somewhere then, since the input is a 12v wall-wart.
                        Wattevah...
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          This little TV is still being worked on by my colleague (though "slave-driver" would be more appropriate term to describe this fella >_>) who refuses to accept my idea that the IC should not get that hot and he's dauntlessly pushing on doing....whatever he's trying to do, so I'll keep you folks posted on how it all ends. This is gonna be good
                          Wattevah...
                          • sintv
                            • Feb 2015
                            • 37
                            • scotland
                            Sorry but I dont understand why youd want to repair an old portable set. Sell him a freeview box and save your energy for a more profitable repair
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              • Romania
                              My thoughts exactly: had it been only the power issue I described, then yes, it would've been worth it because it was cheap and relatively easy to solve, but once we start going any deeper, it's indeed a waste of time.
                              Like I said: I'm not the one working on it at the moment, since of course I would've scrapped it and not even bother, but the old geezer of a colleague of mine likes pursuing these avenues which are completely pointless by wasting time with junk like this which is a waste of time (and money !). Telling him something is trash and is not worth or cannot be fixed is almost like a curse word to him and it sends him into a veritable feat of rage which you, the unfortunate soul who dared "insult" his repair skills, has to fight back....oh boy I could write pages on this guy, but that's enough digressing for today. Like I said: really curious to see how it all ends
                              Wattevah...
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                Ok guys, here's the situation: apparently my "buddy" here did replace the IC eventually (the large one - can't remember what it was) but still no channels, so I was right not to bother....call me a slacker, I know
                                Speaking of which: does moving those coils around affect reception entirely or just some of the channels ?
                                Wattevah...
                                • R_J
                                  • Jun 2012
                                  • 9535
                                  Yes moving the coils will effect the channels, the coils are adjusted by moving the coil windings, It looks like there is a coil for adjusting the i.f. frequency of each band and one is for an i.f. filter
                                  So it will likely still receive channels.
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    • Romania
                                    He managed to fix the thing apparently. He replaced the small chip in the tuner from what I recall, but he also messed around with the EEPROM chip and he claims THAT'S what actually got it going, which I disagree with - it was that IC that solved it...
                                    Wattevah...
                                    • Jacksoft
                                      Samsung 225MW EEPROM bootloop
                                      by Jacksoft
                                      I got an old Samsung 225MW TV with BN41-00825 motherboard.
                                      Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
                                      So I attached the VGA UART cable and read the debug data using a RT809H programmer:
                                      According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
                                      Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts...
                                      02-14-2025, 04:18 PM
                                    • DXseekerMO
                                      Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
                                      by DXseekerMO
                                      I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
                                      As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
                                      09-15-2021, 05:15 PM
                                    • Mark R
                                      Does Changing Out Caps In A Tuner Effect FM Reception
                                      by Mark R
                                      "TQ" Subject at hand is a Marantz 120 tuner. The tuner lit up but no output. Recapped the entire unit. Before it was working fine tuning in Stereo and Mono. Now it just about tunes Stereo and some of the mono stations are weak. Nothing else was changed. When you do hit a stereo station the stereo lamp will come on but flickers as it's trying to hold the MPX signal.
                                      I don't see how bringing the unit back with new caps checked by my Sencore LC103 would effect the FM section. Every Value is as it was from the factory?
                                      Any Thoughts?
                                      06-11-2024, 07:04 PM
                                    • chth96
                                      Is it no harm to replace with capacitor without ripple current rating?
                                      by chth96
                                      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                      Rubycon YK DataSheet (b...
                                      04-19-2024, 05:19 AM
                                    • RetroComputingGrotto
                                      Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
                                      by RetroComputingGrotto
                                      I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
                                      As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
                                      What is your advice/opinion on whether or not on old(er)...
                                      04-03-2024, 08:30 AM
