LG 42LG6000 horizontal lines
    I am very new this forum. I have a old TV model 42LG6000 model. longer to turn on, power light shows red, turning to white, black screen after 5 min showing full screen color horizontal lines. please review photos. I already replaced the LC37WU/LC420WU/LC470WU T-con logical board. Unfortunately, the problem still reaming. do i need to replace the main board? main board parts number is EAX39192001(14). can be work any other parts no similar type board.
    any suggestion would be appreciate.
    Many thanks
    Re: LG 42LG6000 horizontal lines
    This is a standard defect. You check the capacitors in the sub-module front Board t-con.
      Is the sub-module board underneath the tcon? I have the same issue.
      Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
        Also try heating the Mainboard to see if that affects the issue had alot of issues with bad solder joints out of them Mainboards.
          I'll try that first. If nothing then it's the board underneath the t-con?
            The Tcon is the board that the Lvds connects to.
              TV looks like this:
              I did, however, replaced few swollen caps on the PSU.
                Instead try heating the board Maklaud refers to, and power on to see if video is better, if so it is that board that need recapping.
                  If you/he means the board underneath the tcon, then I have heated it up to beyond melting point but same issue.
                  How can I test those caps while in circuit?
                    a good esr meter, dick smith , peak and a few others sell them but they aren't cheap. a real timesaver on electrolytic caps.i like the peak for the fact it has a discharge function and a display of value and esr.
                      Peak are the best in my opinion but Dick Smith are good for the price
                        Hi, this is the most common problem in this TV model. The problem is the two smd capacitors 100uf in the board between the t-con and signal board (C403 & C398). The capacitors are both in the bottom right of the board. Just replace these capacitors and the problem is solved. Do not buy this board in second hand because this problem is very common and the second hand board will fail after some time (the original capacitors of this board are very bad). {found it on internet was posted by DiogoADR i fixed mine that way same syptoms,hopefully someone else will find it usefull although its very old post}
                          Just wanted to say a big thank you. Replaced those exact caps and my TV is working fine again (8 months after the repair! ).
                            Personally speaking I have found far more failed capacitors than the two mentioned capacitors on the EBR50556301 UP CONVERTER TCON BOARD. This is the board directly below the TCON board. I replaced around ten of the 100uF smd capacitors from this board after identifying them using a peak ESR70!
                            Don't be too surprised if it goes again
