Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    Can i help me tout patch m'y bios
      Originally posted by noregret70 View Post
      Hi dani981, can you help me with this T450s , i try patch it but notebook freeze at thinkpad logo. This one have i7 cpu, i patch same one with i5 without problem.
      This is file name power pass. Maybe Power on password?If supervisor password flash this file.If you mean the Power-on password then see p. 34 of thehttps://download.lenovo.com/pccbbs/m...sp40g54937.pdf
        Please feedback to me
          Do you insert lenovotranslatesevice and bootoptions or somerhing else ?
          When I patch file from didouche1200 and compare it with your patch,they are not same...
            User enable all possible password on this one . Thx for help this patch work, it wait a bit long after i press f1 but finaly work.
              i try patched enter any id but laptop freeze at logo and dont enter setup bios
                Hey everyone! I'm just looking for some clarity on the patching process if possible.
                Correct me if i'm wrong, the files that need to be replaced are:
                1- BootOption
                2- LenovoTranslateService
                If that's true, then which section in the BIOS that those files are to be replaced? As I see BootOption for example in different sections and different Header-Offset.
                A clear explanation is really really appreciated.
                  As I told before, use the search to find only LenovoTranslateService. Replace that. Then scroll a bit up or down and you should see BootOptions. Replace that.
                    The problème isolved i just flashed with original dump bios' thanks bro 'tel me how to patch bios
                      i patched lenovo x1 carbon 3rd fen for bios password
                      patch was successful.
                      Now i am getting 7 digit hardware id
                      Hardware id : 6084682
                      can anyone generate the key?
                      if any one has key generator , kindly share as it can help
                        AFAIK key is 3056124
                          Thank you very much
                          the key worked
                            Please i need patched bios for x270
                              Please i need to patch file bios x270
                                  thanks wor biosked ;please tel me how patch
                                  worked bios
                                    Any solution for T480s
                                        Can you help me I have lenovo t450 and x240 with bios supervisor pasword, when I patch bios file laptop freze on first screen, can you patch file for me please
                                          Thanks , worked perfectly on T480s
                                          and for L450 the password was in ps2408 chip , like on older models.
