Samsung UN60H6203AF LED TV Screen Won't Turn On
    Re: Samsung UN60H6203AF LED TV Screen Won't Turn On
    https://www.shopjimmy.com/samsung-bn...re-led-strips/
    According to the LED drive Voltage chart, the Voltage is 326V.
    So how many pair of wires are connected to the LED connector?
    I just reattached the 4 good strips that were working before back to the tv and nothing doing. I was attempting to see if indeed the new led strips were faulty. Not sure if that tells us anything but i know these 4 strips were working prior to all of this.
      Just an fyi for future readers. I never was able to figure out what the problem was. I had the correct voltages but never found out where the problem was for a possible ground issue. I ended up buying another used lower supply and got the tv going again. It has some horizontal line problems that i believe are common with samsung but not too noticeable from more than 10ft away. Thank you to all who have helped!
