Acer ES1-432 (DA0ZQFMB6F0 Rev.F) Bios Clear Me
    Dear, everyone....
    could somebody help Me to clean ME Region for my Acer ES1-432 ?
    Thanks for help...
    Re: Acer ES1-432 (DA0ZQFMB6F0 Rev.F) Bios Clear Me
    try...bios extracted from the Acer site
      Thanks for help...
        I see the clear me bios data is still the same, still press the source 28 seconds later then display the picture
          Post your old dump
            Im working with ACER ES1-432 DA0ZQFMB6F0 no display simptom and was reprogram EC with SAS Programmer and display now working fine but keyboard got problem... When i press W, \ will appear... all keyboard button is not correct anymore... do i flash with wrong file or missing some step..?
              post the backup of the EC bios.
                here is bios i using for flash
                  is taken from the Acer site update..it looks ok ..
                  if you have a Vertyanov programmer you can check the keyboard
                    Hello sir,,do you have a pinout for programming this ec bios on IT8987e chip using RT809f? Tried searching but i can't find it. thanks.
                      May I ask, what exactly is the size of EC BIOS on this Laptop? Because there is an SPI chip near the SIO with 1mb of data capacity, but this EC BIOS you have uploaded is just 128kb? Im confuse. If this is for the SIO itself then what is the function of the SPI chip near the SIO?
                        the EC bios has 128KB and is in the SIO chip..you have the bios in post # 8 ...
                          i have es1 432,,there 2 bios chips 1 has 8mb and the other 1 is 1mb,,,
                          do you have file 1024kb for the other ic 1.8v ic also
                          back-up attached
                            es1 432 charging light only cant switch on
                              use the bios from post #2 and this one..
                              DMI 1E000 - 1E0FF
                                DMI 1E000 - 1E0FF
                                thank you we will update for the result later
