Bios password Dell XPS 13 9370
    I got an Dell XPS 13 9370 with admin password set.
    Already tried the master passwords from bios-pw
    Any of you have an idea how to remove this one?
    System Number: D51WYM2-6FF1
    I can make a dump if necessary
    Re: Bios password Dell XPS 13 9370
    I'm not sure if this is common knowledge but I just tried it and unlocked a couple of 7275 that wouldn't unlock with their 6FF1 master password.
    Manually change the suffix to 1F5A or BF97 and try the password you get from that.
    e.g. D51WYM2-1F5A = Iy2DtA27gQQwyuFA or D51WYM2-BF97 = 8WQmzXZk5L11L239
    Hold left Ctrl and press Enter when you've typed the password.
    Let me know if this works for you.
      For me this wasn't common knowledge.
      but it worked, i removed the bios password succesfully, even on a second unit.
      Thank you!
        hope someone can unlock mine? bios-pw(dot)org diddnt word for me, even not with ctrl + enter
        thanks in advance
          thanks in advance
          Write your service tag with suffix.
          all donations are welcome,
            hope the info is on here?
              service tag is wrote, but where is the suffix?
              is it -6ff1?
              you can find it in bios menu.
                is it -6ff1?
                hope so, the laptop is at a friend and he allready took off the bios chip, because its a wson chip, and he dont want to solder it back to check the suffix because its difficult for him to do that.
                if 6ff1 is the only one that pops up, than should it the right one
                  If this your code (9CNFMQ2-6FF1), so try this one:
                  Dk6akhkLDI[sMPIn
                  be careful with capital and small litters, use QWERTY (US) Keyboard and Use left CTRL then ENTER twice.
                    Dk6akhkLDI[sMPIn
                    diddnt work sadly, here a screen of the bios, hope u can do something with it
                      After put "Unlock button " , what do you have ?
                      Become a Badcaps supporter
                      Thanks to all supporters.
                        then i get this
                          then i get this
                          66qWQJ6mIxWrzxnn
                          GNqNr25LNyMrZMIy
                            Originally posted by miansh621 View Post
                            66qWQJ6mIxWrzxnn
                            GNqNr25LNyMrZMIy
                            both not working
                              [QUOTE=Verlengsnoer;1175812]both not working[/QUOTE
                              send your bios file
                                [QUOTE=aldopc;1175840]
                                send your bios file
                                its here
                                https://www.badcaps.net/forum/attach...5&d=1666817280
                                  hi, i need unlock 9370
                                  this is my service tag CX6HHR2-6FF1
                                  To read the bios is it the IC in the image or is it another one?
                                    Havn`t you tried unlocking it with the password generator.Have you read post #2 ?
                                    BIOS guides, methods, resources and tools
                                    https://www.badcaps.net/forum/showthread.php?t=103526
                                    3. Password removal by laptop brand
                                    https://www.badcaps.net/forum/showpo...42&postcount=4
                                    3.4. Dell
                                      3.4. Dell
                                      Yes, sure
                                      I have tried that method, it doesn't work for me
                                        Yes, sure
                                        use external USB qwerty keyboard
