hp 15-cw0010na bios
    hp 15-cw0010na bios
    hi there
    hp 15-cw0010na , SR: 5cd947477f
    G7BE DAG7BEMB8D0 Rev: D
    anyone can help mewith fixing the bios dump pls
    Re: hp 15-cw0010na bios
    Originally posted by layad View Post
    hi there
    bios extracted from the HP sit6e update, the laptop has three bios variants, yours is 084E5
    DMI 0 - 10FF
    KEYWIN 8000 - 803F
      If you can`t use a hex editor you can still add the DMI yourself using this guide https://www.badcaps.net/forum/showthread.php?t=116311 .
      Follow the Easy guide and use this attached script.
        Follow the Easy guide and use the attached script.
        Hi, it's giving an error. Could you help
          Did you use the script from post #3 .Did you check your backup to make sure its good ? ,post it here
          Edit: I think you could have a double file extension,can you check your windows (explorer) Folder options, look for a setting called "Hide extensions for known file types" and untick it. oldbios.bin should only have .bin ,let me know if its something else after .bin
            Thanks, problem fixed.
              what was the problem
