Hp elitebook 840 g5 bios password
    Re: Hp ellİtebook 840 g5 bios password
    Originally posted by xedry@yahoo.com View Post
    can someone help hp elitebook 840 g5 bios password file, i try to use hp unlocker to 32mb bios files do i need to unlock the ec file also using hp unlocker?
    Try if not succes post the dump
      Hi.
      I've used HPunlocker multiple times and never had a problem. Now I'm trying to unlock the 840 G5, the program generates the _unlocked file but after playing it to memory the password is still there. will you help?
        try this i unlock your file.. update me if it works
          Originally posted by dragus1208 View Post
          Hi.
          Upload the dump from the second bios chip.
          It's not a good approach to solve the matter in this case.
          Become a Badcaps supporter
          Thanks to all supporters.​
            This is my secondary dump.
            Would you share a solution for the future?
                Very thanks. It's working.
                  I know, I know.
                  Have fun
                    Does anybody know how to activate the manufacturing program mode (MPM) of an 840 G5 Motherboard. I need to change the system unique data after replacing the motherboard.
                    Many thanks
                      Can someone tell me how to create BIOS dump?
                        Read that Post to learn:
                        https://www.badcaps.net/forum/showpo...40&postcount=2
                        all donations are welcome,
                          Originally posted by hardware1 View Post
                          Maybe I'm blind, but the HP BIOS update tool only shows me two options.
                          Update or create a recovery flash drive.
                            Did you read the Post? You should to use a Hardware Programmer in order to take a Backup for your BIOS Chips (Main & EC).
                              Oh then, I can't dump it. Thanks for the help.
                                Hi there! I am attempting to remove the bios password from a decommissioned Elitebook 840 G5. I came across post #56 of this thread which fit my laptop's criteria exactly, and followed the directions offered by the response in post #57. I used a ch341a with the BIOS chip soldered onto the adapter to read and verify the original bios and then used the HPUnlocker v1 program to generate the unlocked bin file (both attached here). I rewrote the unlocked file to the chip and then soldered back into place on the motherboard.
                                After putting it together, I'm now experiencing an issue where the capslock button light and power button are flickering (see image ezgif-2-da60db5cdd.jpg). I read that this might be an indication of a bios corruption and I tried to do the Win+B during startup to see if it would reset it, but to no avail. I'm hesitant to desolder and reflash the bios again due to how difficult it was for me to get it back into place, but I will do it if it means I'll have a working laptop again.
                                If anyone could provide me guidance, I would greatly appreciate it. Thanks for your time.
                                  here is your unlocked file
                                    good afternoon. after I wanted to remove the bios password, I flashed a 32mb flash drive, my laptop turns on, the cooler runs at maximum, caps lock flashes 5 and that's it. please help me
                                      these are my bios files. maybe they are damaged. it behaves the same with them
                                        Wich one that you have unlocked , with wich tool !
                                          I took 32 mb from this forum. These are native files with them, the same thing 5 blinks and that's it
