Asus FX505DD Rev: 2.0 BIOS
Re: Asus FX505DD Rev: 2.0 BIOS
Originally posted by ReedZed View PostHere is a photo
Attach the writing on the EC chip.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
Originally posted by reedzed View Postit8987e bxaAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by ReedZed View PostI'm wondering if it's possible to flash a bios dump so that the multicontroller pulls up the EC
About the EC you should use a prober Programmer, read that post.
https://www.badcaps.net/forum/showpo...40&postcount=2----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by hardware1 View PostIt could happen, try first to program the main bios and see the symptoms.
The serial number is not set, usb does not work either. ssd and sata work with interruptsLast edited by ReedZed; 12-13-2022, 03:52 PM.
Originally posted by ReedZed View PostI walked again on the legs with a soldering iron, the keyboard is red, the speaker makes a sound periodically, there is no picture, there is no charging indicator. But if I reboot from the button, it will go into the BIOS
It should be without a serial number because you didn't give me the original file, how can I add it!----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by hardware1 View PostI don't understand you well, what was your main problem and what's your problem now?
Originally posted by jimore View Postpls help me clean this bios
Try this and give feedbackAttached Files
Originally posted by String2016 View PostI need a working bios on this asus fx505dt board id FX505DD REV 2,0, original file orange light turns on keyboard lights then goes off.Already tried bios here in forum but no light. original have light, I have attached the original file and pic of the board.can someone fix this bios please
You MUST:- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Originally posted by String2016 View PostI need a working bios on this asus fx505dt board id FX505DD REV 2,0, original file orange light turns on keyboard lights then goes off.Already tried bios here in forum but no light. original have light, I have attached the original file and pic of the board.can someone fix this bios pleaseAttached Files
