Dell15 3567 15341-1 bios needed
    Re: Dell15 3567 15341-1 bios needed
    Originally posted by hoaca388 View Post
    Vostro 15 3568
    Service Tag: 6LSS3P2
    Thank You!
    Alert! TPM Device is not detected
    Edit:
    I uploaded the file "clear me MX25.bin" from this forum and it's OK!, but the Service Tag is wrong.
    You will help correctly ServiceTag?
      Originally posted by Lukalago View Post
      Thank You!
      I solved the problem by downgrading the bios to v3.1.0 from the DELL website. The no TPM prompt is no longer displayed
        hi
        there is a dell inspiron 15 3567 mb:15341-1 91n85 cpu:i3 7100u . it boot to windows but turn off after a few minutes.
        i clear bios and replace sio chip(mec 1404), but not work and turn off again.
        i test bios in post 36 ,by SMDFLEA. and same problem.
        any help appriciated.
        .Today should be different from yesterday.
          Re: Dell inspiron 15-3567 Winbond 25q128svfq
          This firmware works for my 7th gen - AMD radeon 15 3000 series...
          Thank you mate
            Good afternoon. I have this machine dell 15-3567 TAG JPLC9L2. I tried bios posted by @smdflea with clean me but the screen is blinking and the servicetag is other. Can anybody help me reparing this Bios?. Thanks...
              Latest bios with clear ME region, laptop may restart several times and you may need to enter service tag.
              I don't provide help for people using CH341A and a clip.
                Thanks. Bios working. I also have a problem with flex.
                  thanks!
                  it worked on Inspiron 15 3567, i3 6006u, Uma Graphics no TPM.
                    VEGAS/TURIS SKL/KBL
                    15341-1
                    91N85
                    SERVICE TAG. FW3N3P2
                    pls help me good and clean bios
                      Originally posted by gyro10 View Post
                      VEGAS/TURIS SKL/KBL
                      15341-1
                      91N85
                      Try and give feedback
                        tnx Master work fine 100%
                          Re: Dell Vegas/Turis SKL/KBL 15341-1/91N85 Bios
                          Originally posted by SMDFlea View Post
                          Latest version .
                          test ok
                          working
                          i3 vga amd
                            hello
                            no video, can clean ME and update please!
                            i tested DanielDacko , but got late display like 40s
                            and TPM Alert, board has no tpm, and no option in bios setup to disable it.
                            service tag is CB2V 9L2
                            backup dump atached
                            thanks
                              Originally posted by superhache View Post
                              hello
                              backup dump atached
                              thanks
                              Try this clean me file
                                thanks but no luck, still no video
                                got like 36s of lights then turn off, and watied like 5 min and no pictre
                                if i press power bton again it does the same some blinking lights and power off
                                  this new dump is on factroy mode ,no dmi, tested on more than 15 unit
                                  flash bios and few minute to take around 3 time restart and check with heatsink
                                  if stil you dont have an image than start probing on mbd
                                    thank you!!
                                    and yes, this file worked 100%
                                    awesome!
                                    thanks
                                      Re: Dell15 3567 bios needed
                                      Originally posted by kodinabeel View Post
                                      Please check the attachment
                                      thaks
                                        i need any one clean this bios
                                        reg MODEL :P63F
                                        REG TYPE :p63f002
                                          reg MODEL :P63F
                                          REG TYPE :p63f002
                                          — You are requesting help
                                          If you do not abide by the following rules, your post will be deleted.
                                          You MUST NOT:
                                          Hijack threads unrelated to your request
                                          Post a request in multiple threads
                                          Post a request multiple times
                                          Post in foreign (non-English) languages
                                          Share private contact information
                                          Offer payment of any kind whatsoever
                                          Bump your thread or post more than once every 48 hours. If you do so
                                          you will receive an infraction
                                          Post "clean me", "clear bios", "clean bios", "bios need", "clear me" or other such terms
                                          You MUST:
                                          Read BIOS guides, methods, resources and tools
                                          Try the method at BIOS guides, methods, resources and tools before requesting help
                                          Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                          Use search function in case someone already answered your request
                                          Post under a related thread if it exists
                                          Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                                          Name your thread with model numbers and request
                                          Provide a BIOS/EC dump if possible
                                          Attach files directly to your post instead of linking to external websites
                                          Post what the problem is, be specific - black screen, no boot, running slow, password.
                                          Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
                                          Become a Badcaps supporter
                                          Thanks to all supporters.
