hp elitebook 840 g4 need password unlock
    Re: hp elitebook 840 g4 need password unlock
    Hello can you please unlock my bios?
    Elitebook 840 G4
      Elitebook 840 G4
      Here
      Become a Badcaps supporter
      Thanks to all supporters.
        Originally posted by hoaca388 View Post
        Here
        It works! thank you very much
          Dear, I am asking you to unlock the password for HP Elitebook 840 G4. Thank you very much!
            Here's your Unlocked file.
            all donations are welcome,
              It works. Thanks friend.
                Hey guys, please help with unlock
                  try..
                    Hello friends, can someone help me with this bios that has computrace activated.
                      solved
                        Is it possible to read and flash back the bios in circuit on the 840 G4 using the CH341A? I can see it is possible to solder small wires to the exposed pads around the bios chip. I have the small wire and iron tips, but don't have a hot air station.
                          yes... you can stick wires between the programmer and the bios chip..
                            Hello, can you help me by removing the bios password, thank you
                              Read some of the previous posts.Have you tried RCUnlocker ? .You must post the laptop serial number .
                              https://www.badcaps.net/forum/troubl...before-posting .
                              You MUST:Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
                              • yinlaino
                                yinlaino commented
                                Editing a comment
                                thanks it worked thanks
                              HP EliteBook 850 G4,6050A2854301-MB-A01
                              Use RCUnlocker from post #1
                              Click me to download
                                try and tell ME , use rcunlocker.
                                  yes it worked thank you
                                    Hi, is RCUnlocker used when you don't have the BIOS Administrator password? If so, how do we know which .bin file to use?
                                      Hi, could someone please help me with HP EliteBook 840 G4, sn - 5CG7105G3M
