Dell 15R 3521 Password
    I've dell ins 15 3521
    need password
    i got this on the screen
    System Disable
    E3C65B8A1D0C5F79
    Service Tag
    8FPWJV1
    I try to flash bios but no way
    Can anyone help me with this problem ?
    Re: Dell 15R 3521 Password
    try this
    Dell by serial number
    qqxia670
    9bb4ifmq
    HQgRF5lmVVZe2E7e
    Im Back... sort of...
      Originally posted by ala_borbe View Post
      try this
      qqxia670
      9bb4ifmq
      HQgRF5lmVVZe2E7e
      I try all these P.W but it is not working
      Thank you
        hi dear,
        you can Replaced EC Bios if Problem are not solved then u Replaced KBC with new one..!!!
        (KB9012qf A4)
          yes,you are write kuldeep ,i had also solved the problem ,change or reflash the kbc ene kb9012qf but does not support the new one kb9012qf
            Can you tell us where to buy adapter for kbc ene that talking about.
            Thanks in advance.
              Originally posted by kuldeep View Post
              hi dear,
              you can replaced ec bios if problem are not solved then u replaced kbc with new one..!!!
              (kb9012qf a4)
              +1
                kuldeep thanks for the post.
                I had the same problem today, i will try replacing the kb9012 and let you know the results.
                  ENE 9012 need to be programed via command line or else it will not solve the problem , ask Dycc further infos , shes a member here in the forum
