---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters.
Hi I got HP Elitebook 1040 G4 motherboard DA0Y0UMBAD0 Rev D which is coming on and the fan is spinning fast but not displaying help me clean me, Thanks
Here's your New BIOS, try it and let me know.
Program that file to your 16MB Chip and put your 8MB Chip Back.
all donations are welcome,
>>>>>click on this link to donate via PayPal.<<<<<
Every donation made will go towards server fees and maintenance costs. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Serial Number: 5CD8325W12.
Thank you Hardware1 I have tried your file but it's not displaying, the laptop turns on and it's giving 1 blink on caps lock and then after a few seconds the fan will start running max speed without display
As far as I know, 1 Blink for HP is pointing to a CPU Issue. If you have tried more than 1 BIOS and it's the same, you can go and Post in the Hardware Forum, maybe they can help you there. https://www.badcaps.net/forum/forumdisplay.php?f=23
Hello, I have in my hands an HP EliteBook 1040 G4 (DA0Y0UMBAD0 REV: D) that makes no attempt to turn on, display an image or anything.
I took out the BIOS and flashed one that I found in a forum for this model, and on the first boot it did give a power LED, it showed an image, but I got two HP screens, the first one said:
"Final step of BIOS update is in progress.", after that it turned off and turned on again this time showing the following warning "The BIOS has recovered its identity data from the Embedded Controller due to data mismatch."
When I hit OK, what it did was restart, it went on a black screen, and then it didn't turn on. And it returned to the same thing, that it does not show any sign of life.
I clarify that I only flashed the 16MB chip, there is an 8MB one right next to it, I have not touched that one at the moment.
If someone could help me with a BIOS for this model I would greatly appreciate it, I also attach the original BIOS of this device
Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
