HP BIOS unlock tool
    Re: HP BIOS unlock tool
    Originally posted by gpu View Post
    EC bios
    Try extras site HP..
      After flashing ec bios, password lost, bios settings avalable. But before POST screen show notification
        use the original bios and this EC ..
          No result
            Is it only a dmi problem,or something else has been wiped?if you fill ihe dmi data in your uploaded EC,in the original EC dump it starts at line 5000(using HxD).If you have seen the message in previous models"restoring data from network cotroller" or something like this.It was restored from EC.I am not sure but just to test.
              On hollyday have freetime, chek it.
                Hei. I have HP 850 G1 which i can not unlock via hp HPUnlocker_v1
                I dump both chips (i do not have clue which one is responsible for password)
                Executed by HPUnlocker_v1, erase both of them and reflash.
                Does not work, can anyone remove password for me?
                https://1drv.ms/u/s!AqPFcaDMKFJ_gphn...UHVcg?e=s8HPKi
                  Firstly.. Do not randomly do things like that. If you do not know what to do, ask.
                  You only need to read, modify and write the larger chip. For example named W25Q128FV or something similar with 128 in the name.
                  Secondly.. Your read is very faulty. Did you not verify what you read?
                  Does your laptop even boot anymore?
                    yeap it does
                      Hi... can someone post the unlocker tool again.... the which is there says the archive is damaged... I have a HP probook 440 G4... can this tool help in this model?
                        Hi.. I downloaded the binary file...However the tool gave me some python error when I dragged the binary on the tool... Can you please provide me with the unlocked binary... I am attaching the downloaded binary... my laptop is hp probook 440 g4...
                          update winrar, or use 7zip
                            Thanks ... I was able to extract the tool but the tool is giving an error ...
                              read the instructions for use ... the program works ok.
                                HI... I read the instructions but still could not make it work... I copied the exe and the binary file in the d drive (no folders involved)... I dragged the binary file on top of the tool... The tool gives the error...
                                  post the bios here
                                    hi...please find attached the bios...
                                      try..
                                        Hi...tried with unlocked bios...still getting the password...
                                          try
