Dell Inspiron 3482/3582 bios password
Re: Dell Inspiron 3582 bios password
I've a Dell Inspiron 15 3505 with following Codes after three times wrong password:
System Disable [2719A0F77CE22422]
Service Tag [HV5NXF3]
Please, can you give me the admin password?
Do you need a dump of the BIOS or other informations?
Regards
Oliver
Regards
Oliver----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..
Okay, now I'm able to generate a master password with the System Disable & Service Tag.
I now can unlock the BIOS settings with this master password and CTRL+Enter, but how can I reset/ change the admin password?
I tried in the admin pw section the generated master pw in the first field (old pw) and left the two other fields (new pw) blank, but that doesn't work, it says "Incorrect pw".
Has anyone a clue how I can disable/ change the admin pw?
@pmax
This CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
Originally posted by Stunt View PostInspiron 3482
Service Tag: CHMYF13
plz Remove the password
Re: Dell Inspiron 3482/3582 bios password
Originally posted by madushanka 1234 View Postedi55 la-g094p bios passord locked..pls unlock this
service tag - DqQZ0DX2
Originally posted by Vesko356 View PostUpload your bios backup.
.Attached Files
