Dell Inspiron 5402 Bios Password
    Dell Inspiron 5402
    MKB N TGL 8L MB
    19861-1
    KTKHP$LA
    ST: 54DWF63
    Please Remove Password
    Re: Dell Inspiron 5402 Bios Password
    Originally posted by kingaarbi View Post
    Dell Inspiron 5402
    MKB N TGL 8L MB
    19861-1
    KTKHP$LA
    ST: 54DWF63
    Here you are:
    Become a Badcaps supporter
    Thanks to all supporters.​
      Originally posted by Vesko356 View Post
      Here you are:
      Thanks Sir it's Worked.
        Here you are:
        help me !!!
        I need to remove the admin password from this laptop. Service Tag B4PVV93-8FC8
        Dell Vostro 5402 19862-1
        THANK YOU
          Originally posted by hanhhoang98 View Post
          help me !!!
          THANK YOU
          1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode.
            This bios does not recognize ssd
              With the original locked bios ssd is reconized !
                I have one bios new but cannot save new service tag and fan maximum! You can fix it?
                  help me !!!
                  THANK YOU
                  I need bios file for same
                    Dell Inspiron 5402-5409 and Vostro 5402-5409 models may encounter an issue where the service tag cannot be saved after reprogramming the BIOS. The solution is to use attached BIOS images. 😁 But even after trying this, you might still encounter the same issue, right? 😁😁 Don't panicβ€”the trick is to try pressing the ALT + F keys several times, perhaps up to 10 times, until you see the prompt 'Please select your laptop model.' After entering the model number, you will be prompted to enter the service tag. πŸ˜€πŸ˜€ Good luck
