m1205bfp mb-v1.2 bios dump needed
    Hello.
    I have a cheap, no-name windows tablet in hand.
    It was working until I got into the secure boot options.
    Now, it turns on but won't boot; no picture, just backlight.
    I can't get into the BIOS. I think it freezes right after it is turned on.
    I attached the original dump.
    Thanks in advance.
    Re: m1205bfp mb-v1.2 bios dump needed
    Originally posted by warg6 View Post
    Hello.
    Thanks in advance.
    Try this file, it could works.
    all donations are welcome,
      Hello.
      Thanks in advance.
      some tablets have a way to get into the bios settings or a menu. Try pressing volume up or down,or both together and holding it while pressing the start button
        cleaning the TXE won`t help , it would need the NVRAM clearing or invalidating if he can`t get into the bios settings
          I tried all the button combinations. I also tried shorting the pins.
            I tried, but it didn't work. It's still the same.
              i tried, but it didn't work. It's still the same.
              post serial number or model number clear sticker image
                Understood
                  I only have board code: m1205bfpw mb-v1.2 201507131
                  I'm not sure about the brand/model. I think it's Dexp Ursus Z210.
                    I just got a BIOS dump from an identical working mainboard, but it didn't work. Could someone clear the ME region? Thank you.
                      I have same problem with my tablet, could you solved the problem?
                      Unfortunately I couldn't solve the problem.
