I bought a 2120 from Ebay and it has a problem(Of course). The display shows the trace in about 1/4 inch square of the screen. It seems like it's working but the display size is too small. I have checked the output of the transformer and it seems within spec. I do have schematic, but not sure where to start looking. Any help is appreciated. Thanks.
BK 2120 scope problem
Re: BK 2120 scope problem
Haven't gotten too far, only discovering what is not causing the problem. I had thought I was onto something when I disconnected the leads to the coil surrounding the CRT and nothing changed. I now believe that coil is responsible for trace rotation. Still unknown what can cause the screen to shrink to it's current tiny size. Unfortunately, I have no experience with video circuits. Mostly worked with audio equipment, cell phones, and power supplies. Any guidance would be appreciated.
It sounds like it is out of focus, and no horizontal deflection. Does the trace move or blink at really low sweep speeds, or is it in X-Y mode?
See this old post:https://www.badcaps.net/forum/showthread.php?t=15169
Schematic is here: http://elektrotanya.com/b_k_2120_osc.../download.html
The trace only moves about 1/4 of inch. The best I can get is a 1/4 inch line in center of screen. The focus and intensity adjust work. I need the trace to go completely across screen to see wave form. When I turn off scope the trace will dance to the left half of the screen, leading me to believe the CRT is good. It's like trying to view the world thru a pinhole.
I would guess the power supply voltage is low for the CRT deflection.
Take a multimeter and measure the PSU voltages. The +140VDC, +260VDC rails have test points, and +24VDC, +12V, +5V.
The high voltage -1.9kV you need a HV probe to measure.
It is set up for the right line voltage 115V/230V?
Originally posted by pneumaticdril View PostI had a critical malfunction when attempting to read 2KV without HV probe and consequently I need to get a new DMM.--- begin sig file ---
--- end sig file ---
Originally posted by pneumaticdril View PostOk, I got new meter and tested all the voltage test points and the 240v is only 25v. I checked back at the transformer and only getting 130vac. I am thinking the transformer is the culprit. Now I just have to locate a new one. Any suggestions?Never stop learning
You need to measure the DCV between the two legs of the filter cap C503 for the top power supply, it should have (as you indicated 130VAC reading) 130VAC * 1.414 = about 183VDC.
So check the rectifier but I would suspect bad C503.Last edited by budm; 06-21-2015, 09:04 PM.Never stop learning
