When I use a logic analyser for Timing measurements, I often get short glitches of a few nanoseconds in some cases even though the system under test functions correctly, but when I make State measurements (clocked by a specific signal with a rising or falling edge), the glitches are gone.
So I happened to run into an article about ground bounce, which most likely corresponds to the problem I am having.
Could the logic analyser be introducing ground bounce at the logic analyser, even though it may be a good design?
