Thinkpad l560 bios bin
Re: Thinkpad l560 bios bin
On attached BIOS laptop won't turn. There is just black screen.
I tried cleaning ME, but situation was same.
I tried also other dump from forum (this one: https://www.badcaps.net/forum/showpo...32&postcount=2) with clean ME, laptop works, but my idea of changing MAC adres didn't work out, as maybe something more require to be changed?
I found MAC here:
00829A40 as FE 45 96 FF FE 69 1D 30
00001000 and 00002000 as FC 45 96 69 1D 30
8025F4 and 8299F4 as 46 00 43 00 34 00 35 00 39 00 36 00 (or F�C�4�5�9�6�6�9�1�D�3�0)
In HEX it looks like normal DOT's but it isn't.
I've tried changing ME region into Consumer and Corporate, but still LAN card is visible as unable to switch on.Attached Files
I found MAC here:
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------ā
Originally posted by hoaca388 View PostL560 Laptop (ThinkPad) - Type 20F1 - Model 20F1S0UF00
It's other BIOS version or other ME region?
I found at this link there is in HEX 0088F200 Windows KEY.
I neet to transfer my one. Do you think it's just about to copy 0088F200 - 0088F260 to add key to bios?
Originally posted by rbvndonh View PostThank you Don't know how you do it, but LAN start to work.
Originally posted by hoaca388 View PostIn the file w25q128fv_bad.bin there is no windows key.
Originally posted by rbvndonh View PostI have other damaged board from L570 with key. I want to move key to this board. Could you help making XXXXX- and i will paste my key later? Don't want to use public key or make my one public.
.Last edited by SMDFlea; 05-21-2022, 03:29 PM.
Originally posted by SMDFlea View PostYou can copy it in ok ,everything after the right arrow >
I was looking that newest BIOS hide CD-KEY, maybe it's necessary to downgrade BIOS to older version and then add key or this operation require to change bigger part of BIOS.
i've tried downgrade BIOS to 1.42 (in such i see KEY, but 1,57 start hiding keys).
edit:
i found also at 0019BDC0 somethink about WIN key. Need to analyze WIN and NON-WIN BIOS...Last edited by rbvndonh; 05-22-2022, 01:56 PM.
Originally posted by rbvndonh View PostThis didn't work out. It shows no OA2 key.
edit:
Originally posted by SMDFlea View PostTry the lenovo hardware maintenance disk
Attached is working BIOS, started-up after ME cleaning, but still LAN don't work on this one.
Do you know how to combine both BIOS to have WIN key and LAN working?
Thank youAttached Files
Originally posted by rbvndonh View Posti don't see any option to add Win key in Lenovo disk. There are just some motherboard related keys to add, or i'm blind
Thank you
I compare Bios with OK LAN and NOT OK LAN in Lenovo Diagnostic Tool.
Looks like there is other index / slot of PCIe, so maybe BIOS is adressing wrong hardware?
EDIT:
Fond this possile to change in FIT, attached pic.
will change and maybe will work.
EDIT2:
After changed in FIT PORT5 to PORT3 LAN work again
Thank you for all hints and support!Last edited by rbvndonh; 05-23-2022, 12:46 PM.
Originally posted by Dan20701 View PostHello, I think I have a corrupted bios, Its not turning on and fan
is spinning, Its the original bios the chips has been taken off I have
not used a clip, Would someone be kind enough to have a look
please. Thanks so much.Attached Files
