Panasonic touchbook cf-53 mk2/mk4
    Hi to all.
    I have two touchbook cf-53, one mk2 the second mk4.
    The bios has a password.
    Help, prompt you successively the process of removing the password.
    Re: Panasonic touchbook cf-53 mk2/mk4
    Hi.
    Post your dump bios .
      Originally posted by Andrew_R View Post
      Hi.
      Dump counted Universal BIOS Backup ToolKit 2.0
        Read full bios via programmer .
          programmer I bought in China
          how will I read and put out
          thank you now
            You find spi eeprom in motherboard ?
            BR
              dump Bios eeprom25Q128A- Panasonic touchbook cf-53 mk2
              I ask for help in finding a BIOS dump 16mb-
              with
              a known password or without a password.
              Thanks adavance (My chip has broken)
                Re: dump Bios eeprom25Q128A- Panasonic touchbook cf-53 mk2
                with
                ------S O L V E D------
                  Hello! Could you share the BIOS Dump for Panasonic Toughbook CF-53 MK2
                    I need too the bios dump for this laptop.
                    Thanks.
                      Hi to all,
                      Can someone help me remove the password from my cf-53 mk4 bios? It seems I've tried everything and nothing helps. Thanks in advance!
                        Originally posted by nolina View Post
                        Hi to all,
                        Try this...
                          Originally posted by rioreno View Post
                          Try this...
                          It works. Thank you very much!
                            me too need that dump ! Thanks!
                              Hi to all,
                              Can someone help me remove the password from my cf-53 mk2 bios? It seems I've tried everything and nothing helps. Thanks in advance!
                                bios is not ok, half is empty...
                                  Hi, and how do I read it. What program to use?
                                  Thanks for understanding.
                                    you have to remove the bios chip from the motherboard, put it in a programmer (tl866, ch 341, etc), read the bios chip, make a backup, check the copy in the hex program to see if it is right, put the copy here, and someone when they have time will help you ...
                                      Originally posted by VurdD
                                      Здравствуйте!Та же проблема,нужен биос ,флешка и ноут такие же.Спасибо!
                                      Hello! The same problem, we need a BIOS, a flash drive and a laptop are the same. Thank you!
                                        can someone post or pm the requested bios file? thank you. best regards
