BIOS bin file for Dell latitude 7480
    Re: BIOS bin file for Dell latitude 7480
    Originally posted by trenkov View Post
    Please remove Administrative password.
    Become a Badcaps supporter
    Thanks to all supporters.​
      Originally posted by Vesko356 View Post
      it's a little bit trickier than unlocking, but try and come back with the result.
      Thanks man. I will try it now. Can you PM me? I want to ask you something.
        Thanks, everything works as a brand new
          i think my laptop bios is corrupted. Laptop wont turn on. can anyone fix the bios?
          CAZ20 LA-E131P
          rev 2.0
          Service Tag : 5SRLPN2
            CAZ20 LA-E131P
            rev 2.0
            Try this and feedback. You should be able to enter your service tag
              will try it and give you a feedback soon
                Just wanted to confirm the bios worked like a charm! thank you
                  Please remove BIOS password
                  Dell 7280 E7A8 suffix
                    This thread is about Latitude 7480, your request is for 7280, next time find model related thread (use search option at the top), or create your own. OK?
                      OK so sorry. I was mislead by the first post. Worked flawlessly btw!
                        Hello, I have a problem, after flashing some Dumps. The Ethernet adapter does not work on Windows and Ubuntu. I am providing clean biographies with FIT but no results. First time I flashed Clear Dump motherboard but it was from i5, now I am trying to flash i7 6600u. There is an exclamation mark on the tab with the information that the device cannot be started.
                          I need to modify Dump . Need to change service tag to : C43R5H2
                            this file bios falsh add service tag try reply me
                              Thanks a lot, everything works great, LAN card and USB C.
                                Someone can help me. When i turning on laptop i have alert tpm device is not detected.
                                I trying Clean ME but no positive results.
                                  need ec bios plz
                                    Hallo mein Latitude erkennt das TPM Modul nicht mehr . Kann das mit der ME Firmware im Bios zu tun haben?
                                    Jetzt hänge ich im Bios bei der Version 1.15.1 fest damit die Warnung nicht jedesmal beim starten Angezeigt wird!
                                    Mfg Gerry
                                    Hello my Latitude no longer recognizes the TPM module. Can that have something to do with the ME firmware in the BIOS?
                                    Now I am stuck in the BIOS with version 1.15.1 so that the warning is not displayed every time it starts!
                                    Mfg Gerry
                                      Mfg Gerry
                                      post old bios backup and service tag
                                        Hello the service tag: 88BPTF2
                                        Thanks very much
                                        Gerry
                                          7480
                                          la-131p bios password and late display
                                          can someone clear me and password
