LCD LED EDID EEPRom Dumps
    Re: LCD LED EDID EEPRom Dumps
    Chi mei N154I1-L0B
      How can i make my own lcd/led cable for 30pin connector for programming
      I need help pliz i don't no what to do
        There is a link to a youtube video at post #6 that will help.
        Edit: eDP cannot be read through a modified cable
          I have AUO G150XTN06.8, suppose to be 1024x768 resolution. The manual does not show the EDID data broken out
          EDID reader software from INTEL shows only supported mode is 1920x1080
          * Digital Display 2 *
          Display Name: Built-In Display
          Display Type: Digital
          Serial Number: -
          DDC2 Protocol: Supported
          Gamma: 3.55
          Connector Type: DisplayPort
          Maximum Image Size
          Horizontal - 0 inches
          Vertical - 0 inches
          Supported Modes
          1920 x 1080 (60p Hz)
          Power Management Support
          Active Off Mode Supported
          Raw EDID:
          00 FF FF FF FF FF FF 00 36 7F 03 00 0F 00 00 00
          00 0C 01 04 95 00 00 FF 2F 00 00 A0 57 49 9B 26
          10 48 4F 00 00 00 01 01 01 01 01 01 01 01 01 01
          01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2D
          36 00 00 00 00 00 00 1E 00 00 00 FD 00 3C 3C AC
          AC 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14
          What bytes contain the supported display resolution(s) ?
          I don't see a 0x780 for 1920 anywhere, so not sure how the EDID is encoded?
          Why would manual say the resolution is 1024x768 and Intel reporting tool show supported display mode only is 1920 x 1080 60 Hz ?
            Try these links, the first link shows the EDID structure, the second link is an online EDID decoder and the last 2 links are utilities.
            https://en.wikipedia.org/wiki/Extend...ification_Data
            https://www.edidreader.com
            https://www.nirsoft.net/utils/monitor_info_view.html
            https://www.nirsoft.net/utils/dump_edid.html
              hello my friends . i have 15.6 inch screen ultra slim 40 pin
              need edid eeprom for this type : MT156WHM-N10
              THANKS IN ADVANCED
                Originally posted by ahkh_72 View Post
                Hi
                i need ltn156fl02-101 edid file????
                this is ok
                .Today should be different from yesterday.
                  Hi,I need edid dump for BOE NE156QUM-N5G,it's UHD,mine is corrupted,with some other edid dump from BOE I get brightness but not picture,if anyone can help,Thank you very much.
                    Post the corrupted dump. What model is the laptop its from.
                      Hi,I read it with some programmer,it says 512kb,don't known is it good,It's HP Spectre x360 Convertible Model 15-eb1043dx,Thank you.
                        It isn`t the EDID firmware,its for something else.
                        NE156QUM-N5G dump attached. The chip size should be 2-4KB ,it will be somewhere on the panels pcb ,not on the motherboard.Have you already checked the eDP cable
                        BOE0895 https://github.com/linuxhw/EDID/blob...5/438B1EDB04AF
