Please Bios for Asus X510UNR Rev 3.0..thank you
Asus X510UNR
who can clear ME for me - X510UNR
this dump more than 30 second to display asus logo. thank alotAttached FilesLast edited by SMDFlea; 06-20-2021, 08:45 AM.
Re: who can clear ME for me
Originally posted by honglongyb View Postthis dump more than 30 second to display asus logo. thank alotAttached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Re: ASUS X510U (MB X510UNR Rev: 3.0) not display at all
Ok, attached is the ORIGINAL BIOS de-soldered BIOS Chip from the motherboard Any help will be greatly appreciated. ThanksAttached FilesLast edited by SMDFlea; 08-16-2021, 11:48 AM.
Originally posted by mferna14 View Postok, attached is the original bios de-soldered bios chip from the motherboard any help will be greatly appreciated. ThanksDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Originally posted by mferna14 View PostWith this BIOS update the motherboard turns on, I can see the Keyboard Power LED lit, but the amps on the ampmeter is stuck to 0.03, no movement at all & CPU is cold., With my previous BIOS file it would take around .40 ~ .20 amps up & down fluctating & the CPU used to get warm & then fan turned on. I think that the re-build BIOS is not updated well.
Re: Asus X510UNR
Originally posted by mferna14 View PostThere is NO Sticker on under the memory or on the memory slot. Please check this photos, might help in getting the correct BIOS. Thanks for the cooperation.Attached Files
Re: Asus X510UNR
Re: Asus X510UNR
Thanks "SMDFlea" I really appreciate your help. Now with the BIOS file you send me, all came back to normal, I see the fan running, CPU getting warm & the motherboard taking 0.40 amp which I think is right, but still no display. I can clearly view that the backlight turns on & off & it goes throught the initial septup process like all ASUS do, but I cannot get the image on the screen., Even with the External monitor NO Display. I am assuming still it's the BIOS issue as I can even measure that all voltages are present on the motherboard to turn on. Thank in advance.
Re: Asus X510UNR
Originally posted by SMDFlea View PostIf the bios hasn`t been flashed or updated with the wrong one then the bios posted by @peste should be ok.Try this one anyway .
