Acer Aspire E5-575 Bios
    Re: Acer Aspire TRAVELMATE P259-MG
    Pls help me..this bios no power.
    Ill try to other bios but no display
      Re: Acer Aspire E5-575 Bios
      How is it possible, that your post topic is "Re: Acer Aspire TRAVELMATE P259-MG"
      and it is the 3rd page of the topic " Re: Acer Aspire E5-575 Bios"?
        Build Bios Please My old bios
        Problem Black Screen
        e5-575g i5-7200U DAZAAMB16E0 REV: E zaa x32 GeForce 940MX N16S-GTR-S-A2
          thanks
            Aspire E5-575G
            Become a Badcaps supporter
            Thanks to all supporters.
              Originally posted by Claudiomfa View Post
              Try this file ME cleared.. and EC file for kbc
              thanks works good
                Originally posted by mcplslg123 View Post
                Your bios merged with official acer update for your model. If this bios doesnt solves your problem, its not main bios related. report back
                this one work for me...
                Thank you
                  This work 100% , thank you!
                    Clear me please has display but shutdown for just a secs
                    thank you
                    Last edited by Vesko356; 06-26-2023, 02:12 AM. Reason: Thread hijack! Attached bios dump removed.
                      thank you
                      Read the rules before posting:
                      Do not hijack threads! Look at the thread title. Post in existing related thread, or if there is no any for your model create a new one. Also add serial number, SNID, full model name...
                        Originally posted by saqibcomputers View Post
                        thanks 100% working
                        yes, work
                          thanks 100% working
                          yes, work 100%
                            Originally posted by peste View Post
                            try this bios made from your original + Acer site update.
                            yes, it is work 100%
                              [QUOTE=rojocapo;964660]Hi I have an Acer E5-575-51GG and I had to replace the mobo with a used spare bought on eBay. New replacement motherboard does not detect keyboard and touchpad after the BIOS has taken control. I am able to press F2 to go into the BIOS config menu, but then the keyboard stops working. If I attach an external USB keyboard+mouse I can operate the computer but obviously that would not make sense for a laptop.
                              Could someone check if something can be done to this dump to fix the keyboard issue? I read above that someone had to update their EC. How is that done?
                              That just happened to me that the keyboard or the touchpad did not work, I could only enter the bios but from there no key worked, the same thing that happened to the one in the commentary and I solved it, I programmed the bios and the kbc and nothing was the same The solution was to change the wireless network card is the one that causes this problem. I'll comment on it in case something similar happens to you, first change the network card before doing anything else. I already had that laptop for a month and I couldn't find the fault. and it turns out that it is something very simple I hope and someone will find the solution
                                dazaamb16e0 rev e zaaa zaa x32
                                  Quick question .
                                  Could stupid windows update flash me an uma version on a board with nvidia?
                                  i did the thermal paste and noticed it was ok - then did new windows and windows update + drivers and saw new bios there and alowed it
                                  will take it apart tomorow again to see board model
                                  Just wana know if that could have happened or its just dead gpu.
                                    Acer Aspire E5-575-565G BIOS
                                    I can't see myself out with this model. Issue is a black screen, I tried to flash 4 different BIOS BINs already. Obviously this model was sold with many different specification, original ACER BIOS also contains four different versions.
                                    The one I need is:
                                    Model No. N16Q2
                                    MB: DAZAAMB16E0 REV:E
                                    CPU: Intel Core i5-6267U
                                    VGA: Intel Iris Graphics 550
                                    Original dump attached.
                                    Thanks a lot!
                                      Re: Acer Aspire E5-575-565G BIOS
                                      The one I need is:
                                      Model No. N16Q2
                                      Thanks a lot!
                                      Serial number ?
                                        S/N: NXGE6EV006638135F27600
                                        SNID: 63807934676
                                        Thanks!
                                          SNID: 63807934676
                                          Thanks!
                                          try clean ME version
                                          all donations are welcome,
