bios dump for TOSHIBA PORTEGE R30-A
    Hi, I need a bios dump for a TOSHIBA PORTEGE R30-A-17C.
    Thanks.
    Re: bios dump for TOSHIBA PORTEGE R30-A
    nobody has a good dump for this Toshiba?
    This is old dump:
    (problem with this dump is with intel graphics, it hung when intel driver is loaded)
      This is old dump:
      That's not likely to be a bios issue .
        Bios with clean ME, for those who need it .
          Probably is not a bios issue, but it is something to test before changing cpu.
          It works ok in fail safe mode, also it works in normal mode without graphics driver active.
          The behavior is like a nec-tokin capacitor issue. (it boots well, but when it asks for windows password, goes black and freezes) (no BSOD)
          It is the same whit win-7 or win-10, when it freezes, drains about 1500 mA.
          In bios setup I have tested with core multiprocesing disabled, dynamic cpu frequency "always low" and intel turbo boost disabled.
          Memory ram ddr3L tested in both slots.
          Thanks for your answer.
            @Francisco.s, I faced this very same situation on HP 450 6050A2493101 MB where it works perfectly in safe mode,works well without intel hd driver in normal mode but screen goes blank at login screen when proper intel display driver installed. Unfortunately i could'nt fix it and was not able to find the reason behind such behaviour. Replacing the PCH also didnt helped either. As per some russian site, it has something to do DDR3 ram power but i could'nt locate it. Keep us posted if you are able to solve it.
              I have tested a new cpu and problem is solved.
              Thanks to all.
                Anyone have 8 MB file ?
                or anyone can help repair this bios ?
                Here's my dump, problem is drop voltage
                  try..
                    Originally posted by peste View Post
                    try..
                    i'll try tonight and give result
                      try..
                      tried
                      Result : power seem OK with this bios, but still no display.
                      when i try combine my backup and your build ( only change me region from your)
                      mb won't turn on
                        Good Day to all...
                        Anyone can remove the password for this bios bin?
                          Originally posted by jhuztine2881 View Post
                          Good Day to all...
                          The password is stored in the SMSC MEC chip,not the bios. The only way to remove it is by challenge-response code,or by changing the MEC chip from a donor board that has no password.
                            I need this BIOS 16MB for laptop Toshiba portege R30-A Series PART : PT341N
                            THANK YOU
                              THANK YOU
                              post the backup of the bios
                                Hi, I need a bios for a TOSHIBA PORTEGE R30-A, code board FASRSY2 A3809A.
                                trouble is no display
                                this my old bios
                                  excuse me, my bios was no display / no capslock at usb keyboard,, kode board is FASRSY2 A3809A
                                  16MB FILE
                                  PORTEGE R30-A SERIES
                                  PT343N-IL7072
                                  PR734MAACR7AD71
                                  may someone help me check / repair this file...
                                  the unit is auto on when 19v go there
                                  all PL may get their voltage
                                  amperage 450mA board only with 2 rams
                                  processor get warm
                                  not yet change processor
                                  sorry for bad english im from indonesia
                                    try..
                                    Thanks, This is perfect bios
                                      i also have same probem and same model.
                                        try..
                                        THANKS Peste....its work for me...
