Asus FX505DD Rev: 2.0 BIOS
    I request your assistance from the Asus FX505DD Rev: 2.0 BIOS.
    Re: Asus TUF Gaming FX505DU
    Originally posted by warteam View Post
    Asus fx505dd rev:2.0 bİos lazim yardimlarinizi rİca ederİm..
    try the bios from post # 7
      Moved to a new thread, the DD is a different bios to the DU
        Re: Asus FX505DD Rev: 2.0 BIOS
        Post your bios backup .
          Can anyone help with this bios ?
          Asus FX505DD-BQ060
          MAINBOARD FX505DD MB REV:2.0
          Original dump attached below.
            Asus FX505DD-BQ060
            Never mind.. i found it myself from working laptop
            Working dump here.
              Working dump here.
              Update... It works but the GPU is not recognised. I tried multiple drivers and it doesn't show up in the bios either
              Can someone fix my original dump ?
                bios extracted from the Asus site update.
                  Thank you !!! It is Working!!!
                    peste,, thank you sir,, file tested
                      thanks ... funcions perfect!
                        Asus FX505DD Rev: 2.0 EC Bios
                        Replaced the IC as it was shorted and now it needs programming, does anyone have a working EC BIOS?
                          Re: Asus FX505DD Rev: 2.0 EC Bios
                          Your model EC chip ?
                          Become a Badcaps supporter
                          Thanks to all supporters.
                            It8987e bxa
                              fx505DD rev 2.0 bios needed
                              this is my backup
                              thank you in advance
                                Re: fx505DD rev 2.0 bios needed
                                ASUS TUF Gaming FX505DD/DT/DU
                                  Please help. I have an Asus Fx505DD and windows 10 was made an automatic bios update and now the laptop in not start only batery led show and keyboard light is flicker once when i plug the charger. I tried all bios that i find here but with not result , one bios that i tried was keep light turn on keyboard. I think i need maybe a clean bios , maybe the EC was corupted during bios update and it can not function proper. If i press power buton for aprox 20 seconds its flicker once the light of keyboard .
                                    Upload your original bios file and write your device serial number.
                                    all donations are welcome,
                                      Backup current bios file before flash new bios.
                                        Thanks very much , i will try tomorrow this bios and i will thel you. thanks
