Hello, i tried this bios but the same , only keyboard light fliker once with green color an after its on the batery led indicator , any suggestion ? thanks much
bios extracted from the Asus website update.. the bios you posted is not what it should be.. the laptop's bios is 16MB, either someone has walked into the laptop before, or you have read the wrong chip... what programmer do you have??? what is written on the bios chip
I was try , the same , maybe it could be another problem , maybe the EC is the problem, whem was made update the EC was update , or can be other problem , i will try with a new bios memory , thanks
Is your device is Asus FX505DD (Depending on your device serial number) with AMD Ryzen 5 3550H CPU and 16MB bios chip, or it's an Asus FX550DP (Depending on your original bios file) with AMD A8-5550M CPU and 4MB bios chip?
Here's a new file for FX550DP.
all donations are welcome,
>>>>>click on this link to donate via PayPal.<<<<<
Every donation made will go towards server fees and maintenance costs. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
I use MiniPro programer , i was use original bios GD24f128 and another cip Mx25F128 , i was try all bios from this forum for FX505D, its not turning on, no power led , maybe it could be another problem , i have 3,3v and 5V, and 1,8v for bios supply, its only charge led on and procesor is heating , if i press power buton for 20 seconds its flash keyboard led , thanks , i will try the last bios from hardware1. Thanks hardware1!
Are you sure about those part numbers, check both again and post the exact writing or post pictures of both chips
See post #26 ,the barcode sticker has the right model for the bios version that should be used. see this https://www.badcaps.net/forum/showthread.php?t=96604 .Sometimes there is a QR code sticker instead with the model, and sometimes there`s no stickers or qr codes on a motherboard at all
You made things clear to me, Thank you I appreciate your help .
Tomorrow I will read the whole thread you mentioned.
hi all. someone has a dump main + ec for fx505dd-bq121?
Upload your backup bios, write your device serial number and someone will help you.
I don't have the original bios. After an unsuccessful firmware, the EC broke, as I think. Hard drives and usb ports do not work correctly. Defined but aborted. The BIOS itself is flashed, but the EU comes from the multicontroller and there is no result.
my series number:K9NRCV06119339D
uploaded a non-working dump
Find a sticker on the motherboard to identify the right bios.
Also write your SIO (EC) size.
