LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    found out already that it is the 25q128jvsq
    could u help me to know which chip i should backup and flash?
    i have two winbonds on my X380 Yoga:
    1 - winbond 25q80dvsig 1844
    2 - winbond 25q128jvsq 1844
    thanx in advance ^_^
      I have two winbonds on my x380 yoga:
      25q128
      all donations are welcome,
        Lenovo t480s bios pass
            Man thank u for ur tool!!!
            it saved my locked lenovo x380 i bought it with locked bios and then tried to tamper with the setting with a tool used in windows(i wanted to install ubuntu alongside windows). then i got locked out of my laptop for good saying too many attempts for the supervisor password i could not even boot.
            then bought the CH341A programmer
            removed every battery and power source
            did multiple backups of the winbond 25q128 chip
            did an erase and then flashed the patched one and did as advised
            then turned off and ERASED the chip again(at first i did not reset which resulted in black screen and melody beep sound)
            then flashed the original backed up bios again and did reset as advised
            and voila!!! thanx again
            i bought the laptop for a reduced price due to the locked bios! it turned out a good deal after all
              FYI: This tool worked wonderfully for me.. The said bound computer would be a Lenovo Thinkpad L380 (20m8s0m300).
              I used a Chromebook (LENOVO E500 2ND EDITION). I put the chromebook into developer mode, enabled the Linux environment, installed Flashrom and others, as well as your tool.. All was extremely easy to do since 'apt' is available to install missing packages.
              It all went according to plan, without any hiccups. For anyone who does the same, you just need to keep up on re-enabling the USB port through the various stages so that the linux environment has access to it. There doesn't seem to be a way to make that stick, least not from the menus. Well, I didn't really look into that too far to see if there was any kludges to make it stick - out there - but anyways....
              Where do I send coffee/beer or whatever???? Seriously..
              Thanks again to you and everyone else who posts their trials and tribulations so that we may learn from the paths you have ventured!
              Donald
                How to remove supervisor bios password Lenovo Thinkpad 10 tablet (Type 20C1, 20C3,20E3, 20E4)
                my unlock key hint number : F9AA072A
                  Worked perfect for our Lenovo ThinkPad T480s and its MX25L12873F chip [1], flashed from a Raspberry Pi with a simple SOIC-8 clip from ebay ☺️ Thank you very much for this great tool!
                  [1] T480s has a second chip, a Winbond 25Q80DVSIG, so make sure to read/write the right chip!
                    Thanks for this tool it worked perfect.
                    I got a Lenovo Thinkpad T495s Type 20QK with a
                    Board FA391/FA491 NM-C181 Rev. 1.0 2019-03-21
                    and a Bios Chip from Winbond W25Q128FV 1.8v
                    hoaca388 gave me a the patched Bin file and it worked instantly.
                    Thanks and keep up the good work.
                      hi, i have a T480 with supervisory password, i have managed to get the bios UEFI bin, wondering can someone guide me to find the supervisory password using the UEFI tool?
                      thank you very much
                        Password: E4A2DA7D
                          hi All, as i am new to bios flashing could anyone help me understand the steps in the first page :
                          autopatch -h will output the help info for the command
                          autopatch --howto will output the following instructions on how to use the patched image:
                          **I have created the patch using above method
                          [ HOW TO USE THE PATCH ]
                          STEP 1: Flash and replace current BIOS with the generated patch file (i believe its using the programmer tool)
                          STEP 2: Boot the machine
                          STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                          STEP 4: Enter any character when asked for Supervisor Password
                          STEP 5: Press enter when it shows Hardware ID
                          STEP 6: Press space bar 2x when asked
                          STEP 7: Turn off machine
                          STEP 8: Restore original BIOS (i believe its using the programmer tool to flash back the original , which were extracted and were used to make the patch?)
                          STEP 9: Reset BIOS settings to factory default
                          thanks in advance
                            Hello friends.
                            I have one Lenovo X270 Type 20ks with supervisor password. i patched the bios dump, but is not working.
                            Only Lenovo logo and stuck. Please, some help?
                              Originally posted by brontobyte View Post
                              Hello friends.
                              Try
                              Become a Badcaps supporter
                              Thanks to all supporters.
                                Hello friends.
                                same problem. stuck on lenovo logo
                                  Originally posted by hoaca388 View Post
                                  Try
                                  i put the original bios dump back and is working fine, with supervisor password of course. Why the patched bios is not working? somenthing else to do? Thanks
                                    I don't know either.
                                      Hello friends.
                                      Give this one a try.
                                        have you removed the cmos battery?have you tried to restarte without your ssd,b because it could be the ssd password
                                          Hi, i had the same problem with t550 , i removed cmos battery and used external keyboard, also tape on intrusion/tamp switch. After that patched bios worked as well
