LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by Sainted View Post
    Hi folks,
    New to the thread, having bought a T440p with an SVP on BIOS.
    Dumped bios, tried using the patch with Python installed, a black window appears for a split second, then disappears, no patched file is made. What am I doing wrong?
    Also, my dumps are 8mb in size, and I don't think I can see a second BIOS chip on my T440p.
    Could anyone advise, please?
    Or, if someone is in the mood, could you please patch this file for me?
    I think your dump corrupt bro, make dump again.
    Originally posted by andresi View Post
    Sir, Help me to Patched Bios x250, the patcher always has been eror, btw i use win 10
    Here your patched bios, try and please report. Don't forget flash your original once completed
      Its Work,Thank Y.,,, why im always fail to Patched?
        hello, can I unlock KBC bin file from lenovo t490s with autopatcher? (supervisot password)
          pleas, unlock lenovo T490S. Thank you
            Not working for this model. This solution is only for old model!!!!
              lenovo autopatcher is not opening
                please patch my bios please
                  [QUOTE=omarzedillo;1001331]please patch my bios please[
                  Not working for me!!!
                  Post the dump before clean me
                    [QUOTE=lapfix;1001592]
                    He hasn`t posted his own bios backup,its a bios posted by peste in this thread - https://www.badcaps.net/forum/showthread.php?t=77862
                      I confirm that it works on T470s. Thank you.
                        i need patch for yoga 11e
                          Patched the attached BIOS with the autopatcher, and wrote it to my L470.
                          During startup it beeps a lot (10 beeps or something) and doesn't show anything on the screen.
                          Did I do something wrong? Can someone patch it?
                            I tried again, and now it's working. The supervisor password is gone. Thank you!
                              Which models it supports up to? I'm curious as I have a T490s with SVP as well. Can @Knucklegrumble and @Maxpower3 confirm? Thank you!
                                help me, bios password on Lenovo e430, edge.
                                  Originally posted by CornholioGSM View Post
                                  1) download and install python (i have 3.8.5)
                                  2) download and unpack tool lenovo_autopatcher_0.2.zip to own folder
                                  3) make dump of bios image xxxx.bin, check twice if is dump correct
                                  4) put bios dump into autopatcher folder
                                  5) in autopatcher folder hold shift + press right mouse -> open command line window
                                  6) in CMD write "autopatch xxxx.bin" and wait for results
                                  *** if you got something like python error, then is simple solution - copy all files with bios dump from autopatcher folder to python folder root...for example
                                  C:\Users\vaio\AppData\Local\Programs\Python\Python38
                                  ...then again open Command line in this folder and again "autopatch xxxx.bin"
                                  tested on w7
                                  hi i got this, i don't know what next
                                    after trying for a few times finally resolved, thankyou. now it can work as usual.
                                      T480 superviser password remove
                                      can someone help me to patch this bios dump for T480, python on my pc not working
                                        Re: T480 superviser password remove
                                        See post #182 for a possible python fix .
                                          its because my pc has windows 7 service park 1... i need to reinstall higher windows.... which i will do later, but for now can you help me patching that one please...
