THINKPAD L390 password
    Re: THINKPAD L390 password
    Originally posted by alfredposadas09 View Post
    Flash this bios and press f1 follow the instruction put 1234 password then bios pass should remove then flash the original
    It's not working, Black screen with a melody tone
      Anyone can help me ?? please
        @shiriff47
        Supposing you have a good BIOS backup of your ThinkPad, I suggest to search the forum for a confirmed working L390 file, use that file for the unlock procedure according to instructions and once unlocked flash the Original BIOS.
          Originally posted by AAAC View Post
          @shiriff47
          i have done that already but it wont work just black screen with a melody beep
            @shiriff47
            What's the model number of the programmer you are currently using for this ThinkPad?
              @AAAC
              Thank you, i just did it
              i downloaded a good patched dump than i extract the bios region from it and put it to mine
                nice info thanks
                  hello,please pach this
                    The file you attached is named "patched", so it's a patched already or not? If yes, but it's not working, upload the original dump.
                    Become a Badcaps supporter
                    Thanks to all supporters.
                      Hi, thanks for your reply.
                      Sorry for the lack of words, I applied the patch with lenovo_autopatcher_0.2 but it did not proceed with black screen & melody.
                      Also upload the unpatched bios.
                      thank you.
                        thank you.
                        all donations are welcome,
                        Here you are:
                          It worked fine.
                          Special thanks to Vesko356
                            It worked fine.
                            You're welcome.
                            Consider donation in support of the forum please.
                              any one help me please
                                Originally posted by Knucklegrumble View Post
                                [ HOW TO USE THE PATCH ]
                                STEP 1: Flash and replace current BIOS with the generated patch file
                                STEP 2: Boot the machine
                                STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                                STEP 4: Enter any character when asked for Supervisor Password
                                STEP 5: Press enter when it shows Hardware ID
                                STEP 6: Press space bar 2x when asked
                                STEP 7: Turn off machine
                                STEP 8: Restore original BIOS
                                STEP 9: Reset BIOS settings to factory default
                                [ NOTES ]
                                When booting the patched BIOS you might have to:
                                - Hold the anti-tamper switch down the whole time (use tape)
                                - Remove the hard disk or replace it with a locked one
                                Below is your patched dump, read carefully how to use it in a quote above, then try it and leave feedback:
                                  Could you do it for my bios? I've tried all the files and it doesn't work.
                                    My Bios:
                                      My Bios:
                                      Here you are:
                                        Here you are:
                                        Thank you very much. Did you use autopatcher? I have soldered bios with autopatcher but it gives me a black screen. Is your patch different?
                                          Yes.
