Lenovo IdeaPad 3 15ADA05
    Re: Lenovo IdeaPad 3 15ADA05
    Originally posted by peste View Post
    bios extracted from Lenovo site update..
    DMI 1000-2FFF
    Thanks a lot. This resolved my laptop
    IdeaPad 3-17ADA05.
      Originally posted by tracker1 View Post
      Working bios Lenovo IdeaPad 3 15ADA05
      GS450/GS550&GS750 NM-C821 Rev 1.0
      working excelent
      Note: this bios voltage supply is 1.8v
        hi. where is located serial and windows key in bios file. try find location but not luck. can you help me please. Thank You
        my file added.
        Lenovo IdeaPad 3 14ADA05
        NM-C821
        REV : 1.0
          my file added.
          NM-C821
          REV : 1.0
          Your device information is Encrypted, if you want to move it to a new file, you can just copy the block from offset (0h) to (3000h).
          There's no OEM Windows Key in your dump file.
          all donations are welcome,
            The windows key is in the bios (of course it is encoded) TNMBD-82VXC-XXXXX-WC97G-XXXXX, and the serial number is PF1SM4RC
              That's interesting, because I can't access to them with normal methods.
                wow thx. a client just pop in with the same mainboard. will update later
                  hye i try all bios here. my board NM-C821 14ADA . laptop cant boot keep flash led on switch button.
                    try the bios from post #29..it is for the following laptops..V14-ADA, V15-ADA, ideapad 3-14ADA05, ideapad 3-15ADA05, ideapad 3-17ADA05..if it doesn't work you have another problem..don't forget to make a copy of the original bios of the laptop..
                      Hi, I have successfully flashed the bios with the one provided earlier in the thread and the laptop turned on. However, in BIOS the MTM, Lenovo SN, UUID Number and the other fields regarding the laptop on the main screen are empty.
                      IdeaPad 3 15ada05
                      SN PF272AZ5
                      MTM 81W10097BM
                      Factory ID JVHFC1
                      MO PF9XB0418028
                        IdeaPad 3 15ada05
                        SN PF272AZ5
                        MTM 81W10097BM
                        Factory ID JVHFC1
                        MO PF9XB0418028
                        Here's your New Bios, it's a Virgin Bios from Lenovo with your DMI.
                          Thank you. It is working as expected.
                            You're Welcome.
                              Hi guys, i've a problem with one 15ADA05, sometimes won't boot the OS.
                              If the problem is the bios, the serial number is: PF294VE5
                              Thanks for all, guys
                                did you read post#49???
                                  thank you working
                                    Thanks.Excellent!
                                      I am working on a 17ADA05 NM-C821, I tried putting a bios file with integrated ram disabled, and didn't work, I tried to put my original bios again in the chip but it's not working either, any ideas, this is my original bios file.
                                        Thanks 🥇
                                          This is the latest version from lenovo, try it and let me know.
                                          Hi there. Such a problem
                                          After updating my laptop ... The WI-FI adapter disappeared everywhere and the keyboard does not work at all in Windows itself. Everything works in the bios itself. Changed the update from the site, it did not help.
                                          Product Name: Lenovo V15-ADA
                                          Bios Version : E8CN36WW
                                          EC Version : E8EC36WW
                                          MTM: 82C70065CK
                                          Please help me
