help me ...i need bios GL553 rev 2.0, this my bios whit no display
Bios dump Asus GL553VW rev 2.0
Re: Bios dump Asus GL553VW rev 2.0
Originally posted by digitalpc View PostHere is model based in motherboard stickerAttached Files
Sorry for 3post, I found thread with same problem like me exactly
https://www.badcaps.net/forum/showth...gl553vw&page=3
You probably have one/both failing CPU large capacitor or a failed Phase Mosfet. (usually the 2nd, middle one)
You can confirm this by loading a command line linux from an usb in a "knoppix acpi=offsafe" mode, then: (this will allow only one thread on cpu to load)
1. start a cpu load test. (it will be perform on 1 thread and 100% load fine)
2. then start knoppix linux command line with normal mode and starting a cpu load test up to 8 times (8 CPU core thread).
At one point you probably have an instant shutdown.
(Usualy about 4 or 6)
Hi Everyone can someone help me fix this bios, the problem of this laptop is no power because of shorted vccgt mosfet i replace a new one and the laptop is turning on but it has no display. i will attach the original bios. thanks in advance.
laptop model: ASUS GL553VW-FY002T
board code: gl553vw ver 2.0
sn#:GANOCV16N437438Attached Files
