Hp 450 g6
    Re: Hp 450 g6
    Somebody help me with the bios file for 450 G6 with Nvidia graphics, for some reason the current chip has no data at all, seems like someone tried to program it. I have tried the ones available here powers on but no display the gpu remains cold
      Re: Hp 450 g6
      Write your device Serial Number and Upload your Backup here, we will see and tell you if it's the Original BIOS or not.
      all donations are welcome,
        Re: Hp 450 g6
        Thanks @hardware1, however, as mentioned above, I tried to read from the chip that came with the laptop, there was no data in it if you read it saves nothing so I guess the chip was erased or something of the sort.
        If you are able to help without the original backup, kindly do. Here is the S/N: 5CD052QLVX on the cover.
          Re: Hp 450 g6
          As you can see from the Image, this Serial Number belongs to (HP ProBook 455 G7) not (HP ProBook 450 G6).
          HP ProBook 455 G7 should have (AMD Ryzen 5 4500U CPU), HP ProBook 450 G6 should have (Intel 8th Gen CPU). Which one of those CPUs you have?
            Re: Hp 450 g6
            I am sorry brother for that I had two of them opened, I mixed up, here is the correct serial number 5CD109J72L. But, this is interesting and I had not noticed that, the code written on the motherboard returns it is an hp 450 g6, but the serial number above and back cover model is written as 450 g7.
            I have attached everything if this will help give a clue. Thank you.
              Re: Hp 450 g6
              Motherboard can be used for more than one Model, but I don't think this Motherboard is for 450 G7. (Maybe someone changed the Cover)
              Anyway, I will give you 2 BIOSs for (450 G6 & 450 G7 to try them).
                Re: Hp 450 g6
                Thank you, will let you know
                  Re: Hp 450 g6
                  Unfortunately, none works.
                    Re: Hp 450 g6 need clean plzzz
                    Here's your New bios file, try it and let me know the results.
                    thank you very much
                      Originally posted by andy999 View Post
                      thank you very much
                      Good to know, You're Welcome.
                        Re: Hp 450 g6
                        hello
                        please help to modify hp450g6 bios file
                        I have got hp 450 g6 without bios chip on board
                        the new bios I found worked fine but I have few caps lock blinking before start
                        bios updates ok
                        many thanks
                          Re: Hp 450 g6
                          hello
                          bios updates ok
                          many thanks
                          Why you didn't try the file in Post #29? I think it was for your another device and you replied to me in Post #49.
                            Re: Hp 450 g6
                            hello
                            it`s 2nd laptop / that bios file isnt working here
                            thanks
                              Re: Hp 450 g6
                              this one HP ProBook 450 G6 (R71) (V_1.22).rar
                              working for x8j-8l thanks
                                Re: Hp 450 g6
                                Guys, forgive my illiteracy, I see so many replies with the BIN files for HP Probook450 g6 DAX8JMB16E0
                                I currently need that unlocked working original BIOS for my laptop. Could you kindly reply with the file? Thanks heaps!
                                  Re: Hp 450 g6
                                  Post backup bios and serial number.
                                  Become a Badcaps supporter
                                  Thanks to all supporters.
                                    Re: Hp 450 g6
                                    I haven't got the BIOS dump unfortunately.
                                    S/N: 5CD85O52QG
                                    I am trying to revive a dead laptop. Currently all signs point at corrupted BIOS
                                      Re: Hp 450 g6
                                      S/N: 5CD85O52QG
                                      Try #2
                                        Re: Hp 450 g6
                                        even though it is for da0x8jmb8e0 rev:E not for DAX8JMB16E0 rev:E ?
                                          Re: Hp 450 g6
                                          There is only one bios version for Probook 450 G6 which is R71.
