ok, now it's tricky but you can use a little precision flat blade screwdriver to lift the little tab that holds the wire in place and slip it out of the connector, you want to remove inverter on-off wire from connector on powerboard side, done with tv unplugged from power.
then temporarily just tape the metal end of wire you removed so it doesn't accidentally contact anything, then with that wire out of the way, put the connector back in place, make sure that wire is out of the way and taped off, use about a 1k resistor to jumper from 3.5 to inverter on-off, then test tv.
ok, that should mean that your backlights and powerboard are ok, looks like the damage is on the mainboard, maybe test some things there, maybe check the voltage regulators on the mainboard, some testing there: https://www.youtube.com/watch?v=ocqnqmBxiqY
I check it and no voltage is goint to tcom board. So i guess the MB is dead. I check under microscope whole board and no shorts or visible damage. I found this component and i do not know what is it?
Label A952 (X1002 on board)
...the quieter you become the more you are able to hear...
well it's not totally dead, it's sending some signals but not inv on-off to the powerboard but it could be partially dead, ever since I fixed my sony that was took out by lightning with a firmware update, I never rule out that a firmware update might do the trick but I don't know, the lightning may have just killed part of the board, but if all that is too hard to do, then a replacement mainboard should bring it back to life and may be the simplest solution.
I would try to reflash it but i do not think that there are a fw update online or bios .bin file to flash
Indeed, that's always a problem, the tv makers just can't wait to take the firmware off their sites or just never make it available in some cases, they would rather sell us another tv than give us a way to fix the one we already laid out good money for.
Hey i found a board on ebay but the seller say that the board is from model: 37LD420
The board have the same code on it (attachment). Only EBU number is different but EAX number is the same. Will this work on my 42LD420?
