Please DELL LATITUDE E5430 Bios needed
    mb:QXW00 LA-7901P REV:1.0(A00)
    old bios:
    Re: Please DELL LATITUDE E5430 Bios needed
    Any help please
      100% Working bios, tested today. Ver. A03
        I will try it and let you know
          the problem of this laptop is when you press power the machine goes off after some 5seconds.i do flash with your given files but the problem is still there.
          so i better check the board .thanks
            thanks
              Thank's bro
                thanks
                  Esse .
                  same problem did you find the problem
                    thank u
                      thanks - спасибо
                        thnkx bro
                          100% ok i test it
                            Perfectly working
                              nice thxxxx
                                thx
                                  Thank you very much, it works perfect, I reprogrammed the two chips and it worked ... Greetings from Mexico.
                                  mil gracias funciona perfecto, reprograme los dos chips y funciono ... Saludos desde Mexico
                                    thank u working......
                                      thanks
                                        Thanks, working
