Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Old 11-15-2014, 09:12 PM   #1
PlumBum
City & State: Torshavn
My Country: Faroe Islands
I'm a: Knowledge Seeker
Default Dell 2407 wfpb no backlight
Hi i got an Dell 2407 and the backlight stopped working while i was watching a movie.
The power light and input nr is on, but no backlight.
i have opened the monitor and checked the power board an i seams fine, have also checked most of the voltages and they are fine.
The fuse F1 on the inverter board is blown, and i get 19 volt on the one side comming from the connector,
so the question is what caused the F1 fuse to blow ?
I have checked all the diodes, the three big 2.5A fuses and most of the transistors, they all seams ok.
do you have any suggestions about what caused the fuse to blow, maby the 5V voltage regulstor
PlumBum is offline   Reply With Quote
Old 11-16-2014, 12:34 AM   #2
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Default Re: Dell 2407 wfpb no backlight
That is one of those bad black fuse which is used alot in the CMO Inverter board for LCD TV that I replaced lots of them. I believe that is 1.5A fuse, it is used for the PWM IC on the inverter circuit. I use PICO fuse which you will have to bend the legs, no need to remove the old fuse, you can solder one end to the big copper trace and another end to C9 leg.
You can check the resistance on the right side of the fuse and circuit ground to see if it shows very low Ohm, also check the Output pin of the 5V reg to see if it shows low Ohms, that will the idea if you have shorted circuit or not.
I am not sure if that fuse feed the input pin (left pin, center pin is GND, right pin is Output) of the 7805 or not.
You can also put your meter in DCA mode to check the current draw.
__________________
budm is offline   Reply With Quote
Old 11-16-2014, 07:04 AM   #3
PlumBum
Quote:
No short there, it shows 2mega ohm
There is 2.3Kohm between out of 78m05 and gnd
the 7805 is fed through Q2 an pnp transistor that also seams to be ok, so i belive the 5v circuit is ok, must bee someware else
the Fuse f1 also supplys U1 an 324, and probably a bunch of other components. there are 3 220uF electrolyts on the board, i have ordered some and will replace them
Old 02-07-2015, 08:44 AM   #4
bicycle6228
City & State: Salt Lake City, UT
My Country: USA
Line Voltage: 120VAC 60Hz
PlumBum- Did you get your 2407 Inverter board working?
bicycle6228 is offline   Reply With Quote
Old 02-22-2020, 02:55 AM   #5
DerD
City & State: BW
My Country: DE
I have just to say a BIG THANK YOU, for all the information collected here that allowed me to identify a F1 fuse being responsible for the issue with my monitor. Unfortunately there is no info available how to replace this mysterious fuse with "20" 1:1, a 2A fuse for 500mA regulator seems a bit to much. And 200mA a bit weak, although tests showed a current of 35mA over resistor used for tests in normal mode.
Anyway, I will give a try to a 200mA Polyswitch in 1206, but I have to wait for the shipment from China.
DerD is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
