This board has 14 missing electrolytic capacitors. I have no idea why, that is how I got the board. Whoever removed them did a pretty decent job of it and used flux which was still on the board making it easy to see where they had been working. The only thing I have done so far is used my vacuum desoldering tool to clean the holes of old solder.
As I say, I have no idea why this obviously reasonably skilled person has removed the capacitors as I don't read a short across any of them.
The three near the DIMM and ATX connector slots all read 546ohms (these are all in parallel)
The two near the buck regulator by the SATA ports read 21.8 ohms and are parallel and go to this coil
I'm not quite sure where the other one near the SATA connectors goes to - it doesn't go to the buck coil very close to the dimm sockets like I would have expected. This one reads OC.
Actually while typing I spotted another one missing, near to USB1112 connector.
Other than that there are some 'scuffed' pins in the LGA connector but under the microscope they look pretty much OK.
So I guess the only thing to do first is replace the capacitors. Of the ones still on the board there are some 270uF 16V and some 560uF 6.3V.
None of the missing ones connect to 12V on the ATX connector or EATX12V, so it is a good plan to replace all the missing caps with 560uF 6.3V? And what type are these black capacitors?
Cheers
Cheers
