Does anyone have a datasheet for RS4180BL PLL Chip?
    Hi guys
    Do any of you have a datasheet for this chip RS4180BL ? I have a motherboard which has a short circuit somewhere in this area. It's an Acer H57H-AM2 V2.0. I can't find a boardview for that either.
    Does anyone have any other boardview that uses this PLL chip? That would probably help me at least identify the pins where I am seeing the short.
    I only really think there is a short as I have an MLCC capacitor right by the PLL that reads short directly across it, it's not the capacitor itself that is short, but both sides are short to ground and I don't see any logical reason for fitting capacitors to the board with both sides connected to ground.
    Follow me on YouTube
    Learn Electronics Repair
    Re: Does anyone have a datasheet for RS4180BL PLL Chip?
    Hi. Maybe the attached will help?
      Looks to be a standard 32 pin QFN package with pin # 33 = middle ground pad (belly).
        Thanks Mon2
        That could help a lot
        I've replaced the RS4180BL but still have the short
          Where is the short?
            Ill have another look when I am at the workshop tomorrow....... though i have a laptop on my bench right now that I need to fix first.
              OK Mon2 Thanks for the datasheet - it helped to some extent.
              The short was the RS4180 itself - I traced it back to the FET or LDO that powers the PLL, and when I powered the motherboard up I got a bit of smoke from the PLL chip. I removed it and the short had gone. I thought I had already replaced this before but I left it on one side for a long time, so I could be wrong
              Anyway I fitted a replacement (new), but the motherboard will still not boot up. My POST analyzer says 00 or 04. The CPU gets warm but not very hot.
              Looking at the RS4180 I now have CK3V and CK3VA at 3.3V. The Xtal is oscillating but I have no clock signals generated. The other pins seem to make sense all bar one which is at 1.06V
              Here is what I have (Low - 0V, High = 3.3V)
              26 / 27 X1 X2 - Oscillating
              29 REF/SLC - Low
              23 SCLK - High
              2 SDATA - High
              2 PWRGOOD - High
              18 RESET* - HIGH
              8 FSLB - Low
              4 48M/FSLA - 1.06V (is this wrong???)
              All clock outputs LOW
              6 / 7 (PCH/VGA)
              10 / 11 (PCH / SATA)
              14 / 15 (PCH / DMI)
              20 / 21 (PCH)
              I think my soldering is OK, please see pics and check it.
              I need to know where that FSLA signal on pin 4 is coming from or going to, what it is, and whether 1.06V is incorrect. The schematic you gave me for this chip is taken from the correct motherboard H57H-AM2. Do you have the rest of it?
              Cheers
              Rich
                OK I can answer my own question here
                Those signals FSLA, FSLB, FSLC come from jumpers on the motherboard that set the Bus speed to 133MHz/100MHz
                The jumpers select between Ground and PCH_1P05V.
                On my board I can't see any physical jumpers for this so I guess it must be hardwired but anyway
                My CPU is i3-530 2.93GHz = 22x 133MHz
                Jumpers
                1 0 0 = 133MHz
                1 0 1 = 100MHz
                FSLA 1.06V FSLB 0V FSLC 0V = 1 0 0 so it all makes sense.
                PWRGOOD = High
                RESET* = High
                26/27 Xtal oscillator is running
                All the other pins are either 3.3V power, Ground or clock outputs, apart from two.
                Those two are 23 SCLK and 24 SDATA - Now this is an assumption but it seems possible that these clock data into internal configuration registers in the RS4180BL and thus enable the PLL. I had a look on my scope but I can't see anything happen at power on - they just go from low to high and stay there
                The only way I can think that data could be clocked into the the RS4180BL would be if the PCH did it, as that has it's own 25HMz crystal (which is oscillating though only about 25mV high unless my scope is not too good at that frequency)
                To be honest there are too many gaps in my knowledge here and that is why I am struggling. The PLL drives the PCH clock (PCH, PCH DMI, PCH SATA, PCH VGA) but the PCH has it's own Xtal 25MHz. So does the PCH start the PLL and why does it need the PLL?
                Can anyone of you guys help untangle my brain so I can understand what is (or should be) going on here? H57 Chipset
                I have this datasheet
                https://cdn.badcaps-static.com/pdfs/...5c3d593ca5.pdf
                But my head is fried lol
                The CPU is compatible with this motherboard and has Vcore 1.02V, the PCH has power 1.8V, 1.06V, 3.3V. Both CPU and PCH get a bit warm
