Hello i need the schematic or boardview for Drift_SKL 16801-1M, these is my laptop and have a restart problem, show the led indicator of on while 5 or 10 seconds and then go to off, these happening always and dont start, so for fix it i need the shcematic or boardview. thx for all
Acer SP513-51 Drift_SKL 16801-1M Help finding what component it is.
Probably is some kind of HALL sensor (double?)
4 legs, one to ground, one 3.3V .. the other 2 have no voltage.
the laptop is an Acer Spin SP513-51 (no schematics available)
the issue is that the laptop is coming-on only flecting the board (a broken USB port "curved" the board)
and when releasing the board , the screen become totally black (video cable is ok) like some sort of black-mode when lid is closed.. but laptop continue working without backlight.
now i'm thinking that 1 signal that need to be send to HALL (the 4th leg?) is missing (broken trace inside board?) .. some sort of ENABLE signal?
and the HALL sensor is not pushing 3.3V to another leg, can't find any datasheet similar to this SMD... asking help if someone know this can of sensors..
thank you!
on diode-mode i have .5V on the 2 legs that i need to identify.
Re: Acer SP513-51 Help finding what component it is.
Originally posted by Bartoloni View Postthe lapètop is an Acer Spin SP513-51 (no schematics available)
HI SMDflea.. thera are 2 different boards for this model (2 diffierent names for what i know..but the one i have is Drift_SKL 16801-1M)
and the component is between USB 3.0 and USB 2.0 ports
Originally posted by rielfreak View Postno response on one of the pins when you put magnet on top of it?
there is also another board schematics request on teh forum:
https://www.badcaps.net/forum/showthread.php?t=89293Last edited by Bartoloni; 11-01-2021, 06:33 AM.
Re: Acer SP513-51 Drift_SKL 16801-1M Help finding what component it is.
Originally posted by SMDFlea View PostThe schematic and boardview are available at some paid sites,can`t find it on any free sites.Hopefully someone will post it .
Acer Spin 5 SP513-52 Wistron Woody WL 18734-1M Slinky WL 18753-1M
thank you Lazrdo... i also have this scheme... but looking at the sensor is on a secondary board (with audio jack and USB) in this model i have a second card but without any sensor, just buttons, led and a card reader... i saw LID_CLOSE and LID_CLOSE2 (2 signals) but i can't understand from where they are coming. on the scheme you provided there is something similar to a LDO used in the USB area?
[edit]i looked to (i think) every schematic about ACER SPIN series ... and there is one that is the
Acer spin 1 sp111-34n that have a 5 legs hall sensor... called BU52013HFV... that looking at datasheet uses the "G" letter to identify GROUND... and H to identify output (in this cas my H is 3.3V )Last edited by Bartoloni; 11-01-2021, 09:39 AM.
Originally posted by Bartoloni View Postthank you Lazrdo... i also have this scheme... but looking at the sensor is on a secondary board (with audio jack and USB) in this model i have a second card but without any sensor, just buttons, led and a card reader... i saw LID_CLOSE and LID_CLOSE2 (2 signals) but i can't understand from where they are coming. on the scheme you provided there is something similar to a LDO used in the USB area?
