HP Elitebook 840 G6 bios password
Re: hp elitebook 840 g6 please help bios unlock
Originally posted by krogs214 View Postanyone can help me Hp elitebook 840 g6 to unlock
thanks
Re: HP Elitebook 840 G6 bios password
Originally posted by yuri3185pcnet View PostGood day everyone..Can someone remove password and computerace on my hp elitebook 840 g6.. thanks your help will much apreciated..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
unlock this please it has swatlock/computrace. TIA
SN: 5CG9311TZC
i managed to unlock the bios password by myself in neo hex editor the 16mb chip. but my problem now is the absolute lock. my patch doesn't work from files i compared here.Last edited by rex98; 08-15-2023, 03:03 AM.
Originally posted by rex98 View Postunlock this please it has swatlock/computrace. TIA
SN: 5CG9311TZC
i searched the dmi data in unlocked bios then trasfer my dmi to the unlocked ones and now it works.
HERE'S THE GUIDE HOPE YOU ALL UNDERSTAND.
USE MY BIOS DUMP IN THE ATTACCHMENT HP 840 G6 SWAT UNLOCKED.
SERIAL NUMBER BLOCK ADDRESS : 00749807 , 00757cab , 00794cfd , 007a6dc5 , 007a6e89 , 018fd9ee , --> edit and put your serial number in that 6 address
SYSTEM BOARD CT BLOCK ADDRESS: 007aaf51 and 018fdaf4 -->edit and put your CT number in that 2 address
MAC ADDRESS: 01900040 -->edit and put your MAC ADRESS in that address ITS ENCODED IN UNICODE STRING SO DONT DELETE THE DOT.
BUILD ID: 018fe754 -->edit and put your BUILD ID in that address
THEN IN FIRST BOOT GOTO BIOS PRESS F10 RESET SECURITY TO DEFAULTS. THEN USE MPM TOOL IN WINDOWS PUT ALL THE DMI FROM YOUR BOARD are LOCATED in THE STICKERS..
MAKE SURE YOU FORMAT THE OLD SSD WITH LOCK BEFORE BOOTING TO WINDOWS. I USED HEX EDITOR NEO CRACK.Attached Files
Re: Hp elitebook 840 g6 locked bios
Originally posted by Elaid02 View Posthi badcaps team
need remove Password for this bios
Here bios attached
Product Name : HP EliteBook 840 G6
System Board CT Number: PHWHN00WBD3I1V
SERIAL :5CG9497JF1
BUILD ID :19WWCFBT601#SABF#DABF7
FeatureByte : 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gn
give feedbackAttached Files
Originally posted by newstory View PostPlease need unlock 840 g6
SERIAL.: 5CG9500WHD
thanks
BIOS guides, methods, resources and tools
https://www.badcaps.net/forum/showthread.php?t=103526
3. Password removal by laptop brand
3.6. HP
BIOS password is stored in NVRAM in the BIOS. BIOS editing and re-flashing is required.
You can use the automatic unlocker at: https://www.badcaps.net/forum/showthread.php?t=98539
Another tool that may also work: https://www.badcaps.net/forum/showthread.php?t=103184
.Last edited by SMDFlea; 09-18-2023, 07:42 AM.
SERIAL.: 5CG9500WHD
thanksAttached Files
Originally posted by Elaid02 View Postneed unlock this bios
here both 16mb and 32mb dump
Become a Badcaps supporter
Thanks to all supporters.
next time use any hex editor or rc unlocker.
here's the block address of the g6
0037000 to 00037b40 replace with ff.
Originally posted by rex98 View Postsince you didn't upload the 16mb try this. ON FIRST BOOT RESET SECURITY SETTINGS IN BIOS. THEN PUT THE DMI MANUALLY VIA MPM TOOL.ALL YOUR DMI ARE IN THE BOARD STICKERS.
System Board CT Number: ...
SERIAL :...
BUILD ID :...
FeatureByte : ...
give feedback
The system is in MPM unlocked mode and I have set the CT, Serial and Build ID using HP BCU.
WnDMIFit gives a Board Not Supported error and runs in read-only mode.
Any advice please?
