elitebook 850 G7 password
    Re: Hp 850 G7
    Originally posted by hoaca388 View Post
    Try and report :
    thanks this worked. I just had to write the bios.
    Can you teach how to do this?
      Re: elitebook 850 G7 password
      Your Me region has problem.
      Clear vss2 store of bios file.
      Change serial number by bites 00.00 in ec file.
      Become a Badcaps supporter
      Thanks to all supporters.
        I have the same problem with the same model device. but i can't fix it, can you help me? white screen after windows opens and updates
        device freeze
        how to remove swat device freeze.
        I think the windows key number registered in the bios becomes active when connected to the internet.
          device freeze
          Post more EC file.
            Originally posted by mah3r0
            I need bios dump file bin for hp 15-fa0031dx
              Dear all,
              Which chip should be read to remove the BIOS password?
              On my HP 850 G7 I have :
              - 1 Winbound W25Q80DV at the back of the motherboard
              - 1 MXIC MX25L12872F at the back of the motherboard
              - 1 Winbound W25Q256JV at the front of the motherboard
              Thanks for your help.
                Originally posted by FrankTJ View Post
                Dear all,
                MX25L12872F and use RCUnlocker
                all donations are welcome,
                  Thanks a lot,
                  I will give it a try and let you know.
                    I read the chip and used RCUnlocker.
                    It wiped out an 'NvramActiveRegn' section of about 2075 bytes in the bin file at offset 0x37000.
                    However, it was not able to detect the device type/name/serial...
                    Is that still OK? Should I resolder the chip back?
                    Regards,
                      I soldered the chip back and the laptop cannot boot.
                      The CapsLock key flashes 7 times then nothing.
                      Any hint?
                      Regards,
                        I have one HP 850 G7 laptop, whick locked by BIOS paswword after upgraded Windows 11 pro. I tried RCUnlocker_v_1.0 and not work. Can you help me?
                          Originally posted by andrewl
                          i have one hp 850 g7 laptop, whick locked by bios paswword after upgraded windows 11 pro. I tried rcunlocker_v_1.0 and not work.
                          Can hoaca388 help me?
                          flash only 16mb
                            Originally posted by farouk_1994 View Post
                            flash only 16mb
                            Thank you. I will try it and report the result.
                              i have a laptop elitebook 850 G7 bios without passwod but when i install w10 i stucked in wifi configuration (company e mail)
                                Post your dump here
                                  flash only 16mb
                                  I flashed the BIOS chip and not connected the CMOS battery and laptop battery back.
                                  1. connected ac adapter
                                  2. keyboard board light on after 20 seconds
                                  3. screen flashed, cpu fan run fast about 20 seconds
                                  4. power shutdown (auto), about 30 seconds
                                  5. power on and cpu fan run fast about 40 seconds
                                  6. restart, HP logo appear
                                  7. screes show BIOS password required. same before.
                                  any more help? I guess EC need some modified.
                                    flash this
                                      Try this bios i have flash mine work fine make sure you flash 16mb bios chip will work
                                        hp 850 g7 device freeze eror. please help me...
                                          Hello i have the same problem , bios pass . HP elitebook 850 G7 Sn5C116722N
                                          i have tryed to unlock these file,s , with hp unlocker and Rc unlocker , but no luck , pass is stil there.
                                          can you Clear the files for me .
